Old 02-03-2013, 01:23 AM   #26
motorcritter
motorcritter's Avatar
Re: Truck failed emissions
When I worked for Honda, when we had a car that would fail Maryland emissions, a valbe adjustment and an oil change always did the trick (unless the motor was so clapped out, it would never pass). Seems like a lot of unburned fuel can end up in the crankcase and play hell on the numbers.
Probably don't need a valve adjustment, but an oil change- if it's been 'a while'- might help.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 02-03-2013, 02:03 AM   #27
Lattimer
Lattimer's Avatar
Its got about 50 miles on the oil.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 02-03-2013, 06:32 AM   #28
ekgguy
ekgguy's Avatar
You might try looking at the jets in the carb. Might have to rejet. My dad had to do that to get his old Galaxy to pass, but he had a Holley carb. Just my .02
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline   Reply With Quote
Old 02-03-2013, 07:58 AM   #29
JointTech
JointTech's Avatar
wow i thought California was bad but I dont have to smog mine at all. 1975 and under I think.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 02-03-2013, 08:28 AM   #30
biohazardbill
Hmmm weird. In Michigan (when i lived there and they had emissions testing) they didnt require it on cars past a certain year since they werent factory built to the current emissions specs. I dont see how they can force you to pass a test that the car wasnt originally meant to pass in the first place. It's like seatbelts. Until it was mandatory and not an option they cannot give you seatbelt tickets for cars that werent originally equipped with them.
biohazardbill is offline   Reply With Quote
Old 02-03-2013, 09:57 AM   #31
Eddie H.
Eddie H.'s Avatar
First off, it sounds like your idle mixture is too rich.
If you're idling at 1000 RPM, you could be pulling fuel from the transition circuit\ primary jets also. Back the idle down to 650-700rpm.
To adjust the idle mixture for best emissions, turn each screw in until the idle starts to get rough, back out until it smooths out, then turn each mixture screw back in very slowly until the rpm just starts to drop. For the emission test, you might want to go another 1/8 to 1/4 inch farther in past that point.
If you have a vacuum spark advance distributor, unhooking the vacuum line and plugging it during the test may also help.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 02-03-2013, 10:58 AM   #32
Lattimer
Lattimer's Avatar
Idle was 700 on the first test. I had read that increasing it might help, so I turned it up to 1000 for the second test.
Thanks for the tips, I'll try that.
Shawn
Old 02-03-2013, 03:29 PM   #33
sleepertruck72
sleepertruck72's Avatar
High HC's are mostly problems with ignition components. Since you already have gone through these, I agree with the rich running carb. being the culprit. Also, if you have not already or recently, I would replace the PCV valve...
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 02-03-2013, 06:12 PM   #34
sixtysevengmc
village idiot
sixtysevengmc's Avatar
Edelbrock carbs are extremely sensitive to dirt and other contaminates in the fuel.
sixtysevengmc is offline   Reply With Quote
Old 02-03-2013, 10:27 PM   #35
Lattimer
Lattimer's Avatar
That's new also.
Shawn
Old 02-03-2013, 10:28 PM   #36
Lattimer
Lattimer's Avatar
I have heard that. I put an inline filter in right before the carb, but it may have gotten crap in it before I did that.
Everything seems to work fine other than the emissions though.
Shawn
