Old 02-03-2013, 02:13 PM   #1
gabe2000
Clearing out the external volt regulator
I have already disconnected external regulator but I need this space cleared out for windshield washer/ coolants resuviour. The old external reg. Still there with two wire connected. How can remove without effecting the good work truck????? Thx
gabe2000 is offline   Reply With Quote
Old 02-03-2013, 05:35 PM   #2
blazins10
blazins10's Avatar
Re: Clearing out the external volt regulator
what color wires are the 2 left?
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 02-04-2013, 10:46 AM   #3
gabe2000
Two outter wire blue/ brown are connected together . two inner are white/ red are left connected on the connection thermal. What effect would there if I plug wires and remove the ex regulator???
Old 02-04-2013, 09:56 PM   #4
64shortbox
64shortbox's Avatar
Here's a link for you on how it's done with pics. Hope it helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
When I added my washer/radiator recovery tank (from a 95 Ford Explorer) I took the lazy way out. I just flipped the voltage regulator & horn relay to the front side of the radiator support using the original mounting holes & moved the horn (now horns) between the grille and the radiator support like a 75 Chevy truck.
64shortbox is offline   Reply With Quote
Old 02-04-2013, 10:22 PM   #5
gabe2000
I like that. Just move them to the other side. its better safe then sorry. i am fixing signal light and horn. thx
