Building Solvent tank help please
Hey guys I was wondering if anyone out there could tell me what the process is in building a solvent tank. I have a sink already but I have no clue what kind of pump to use or what kind of filter set up it needs or how I could build them....any and all help would be greatly appreciated..... Also any product suggestions as well.....ex. Good pump to use.....thanks devan
Posted via Mobile Device |
Re: Building Solvent tank help please
You could always just use diesel for your solvent and then use an electic fuel pump. Filter could simply be one of those el-cheapo inline Fram fuel filters on the suction side of things. But you can usually find a housing for a spin on fuel filter, which an electic pump will suck fuel through just fine.
Diesel seems to work well enough for anything I work on. Mind you, it leaves the oily film on everything so if you need parts to be clean and dry afterwards, you may want to keep a can of brake cleaner handy for a quick rinse. And diesel is cheaper and more readily available than solvents around here. |
go to harbor freight and buy a replacement pump with hose, i think i paid $20 or less for mine. i just sits in the tank.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#4 | |
