Old 02-03-2013, 07:13 PM   #1
texasbigbear_wink
texasbigbear_wink's Avatar
Need Help With Tires
I have a 1987 chevy LWB with 255/55/18 on front and currently have 265/60/18 on back. I would like to have a much wider tire in back without going taller. What tire do you guys recommend? Thanks
87 Chevy R10 LB
02 Nissan Sentra GXE
texasbigbear_wink is offline   Reply With Quote
Old 02-03-2013, 07:29 PM   #2
Dylan86
Dylan86's Avatar
Re: Need Help With Tires
Use this site... you can punch in different tire ratios and sizes and see how they compare to what you have on there currently
http://www.tacomaworld.com/forum/tirecalc.php
Dylan86 is offline   Reply With Quote
Old 02-03-2013, 08:12 PM   #3
texasbigbear_wink
87 Chevy R10 LB
Old 02-05-2013, 12:39 AM   #4
Dylan86
Dylan86's Avatar
nice truck texasbigbear_wink! how much did you lower it?
Old 02-05-2013, 01:32 AM   #5
texasbigbear_wink
Thanks, Not sure of exact number of inches but I just did a axle flip on the back with 3" drop spindles on front and cut one coil off. I will try and get a stock pic of it up so you can c how much it dropped.
87 Chevy R10 LB
Old 02-05-2013, 01:48 AM   #6
texasbigbear_wink
Before.
87 Chevy R10 LB
Old 02-05-2013, 07:48 PM   #7
Dylan86
Dylan86's Avatar
looks real good! i did a 3" drop spindle with the 1 coil cut on mine also, just cant decide what to do on the rear,,, the axle flip i thought was 6" drop, but it doesn't look as drastic as i thought! did you have to notch the frame?
Old 02-06-2013, 02:07 AM   #8
texasbigbear_wink
I have not but need to and will be doing that soon. The axle is only about 2 to 2 1/2 inches from bottom of the frame. It will ride just fine but a big bump or load will cause it to bottom out on the axle.
87 Chevy R10 LB
Old 02-06-2013, 11:22 AM   #9
G8DAN
G8DAN's Avatar
Looks good man!
G8DAN is offline   Reply With Quote
Old 02-06-2013, 12:39 PM   #10
texasbigbear_wink
G8DAN Thanks.
87 Chevy R10 LB
Old 02-06-2013, 12:49 PM   #11
77ChevySharkBite
77ChevySharkBite's Avatar
The width you can go also depends on what rim width you have, if you have for example 15x10, I've heard of people putting a 295 on the back.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 02-06-2013, 01:08 PM   #12
texasbigbear_wink
They are 18x8 front and 18x9 on back. I was looking for someone that new tires really well to say Ok your running a 265/60/18 and you want to go wider but not to much taller you can run ? The problem I have using the tire calculator is that I find a size I like but that size will not be available.
87 Chevy R10 LB
Old 02-06-2013, 01:38 PM   #13
77ChevySharkBite
Yeah I understand what you mean, in my honest opinion the widest you can probably squeeze on your truck is about a 285 with the rim you have on the rear right now.
Korwin
