02-04-2013, 02:32 PM | #1 |
67 5 LUG conversion kit ?
Looking at converting my 67 over to 5 lug so I can start ordering my brakes and wheels but just not sure what i need exactly. I dont want to end up with extra parts.. Thanks !!
02-04-2013, 05:32 PM | #2 |
Moderator
Re: 67 5 LUG conversion kit ?
As far as parts, you need a set of five lug conversion axles, axle seals, and a differential cover gasket. Swapping them out is pretty straight forward and not very difficult.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-04-2013, 09:54 PM | #3 |
up^^^
02-04-2013, 10:00 PM | #4 |
What kind of brakes are you wanting to order? Are you going to lower it also? Need more info???
02-04-2013, 10:01 PM | #5 |
cpp sells a conversion kit if you want to go with all new stuff: http://www.classicperform.com/Store/...k/6569RACK.htm
02-04-2013, 10:35 PM | #6 |
check out my build thread. My 12 year old son and I swapped out our 68 rear axels.. pretty simple swap.
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, My 68-SWB Photo Build Thread All my Google Albums |
02-05-2013, 09:45 AM | #7 |
Going with Wilwood brakes all around. The truck is static lowered now 3/5. Will be lowering it more. Still not sure if I'm going to lay frame or not.
Posted via Mobile Device |
02-05-2013, 11:00 PM | #8 |
From what I understand, most disc brake drop spindles push the wheel out. CPP says 1/8" but some other drop spindles move the wheels as much as 3/4" outward. CPP makes a "modular" spindle that actually keeps the wheel tucked in or further in than stock. Just something to think about so you make sure your wheels dont rub on the fenders.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
02-06-2013, 12:26 AM | #9 |
you can have your axles redrilled for dirt cheap ! hudlow axle in tennessee does them for 150 for both and their number is 423 362 3006
02-06-2013, 09:16 AM | #10 |
Not to hijack this but I have a similiar question, I plan on converting rear to 5 on 5 however plan on keeping the drums in the rear. What drums would I need to purchase and would I also need to change the backing plates?
02-06-2013, 01:20 PM | #11 |
you can have your axles and drums redrilled for 150 in tennessee at hudlow and they are done right !
02-06-2013, 02:10 PM | #12 | |
Can't seem to find it on the website to check the pricing.
