Old 02-05-2013, 12:07 AM   #101
Squareforceone
Squareforceone's Avatar
Re: "The Yellow Truck"
Damn i wish i had your budget... Lol looking good man love that Lincoln too btw
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 02-05-2013, 01:01 AM   #102
dan468
dan468's Avatar
Originally Posted by jkeating1 View Post
I am pumped on this trans combo! I have a T56 sitting on the table waiting on me to get my butt in gear! Why did you prefer mechanical clutch instead over hydraulic? You might save me some headaches!
I wasn't as familiar with hydraulics, with it being so cramped I wasn't sure how to do the mounts. I also heard horror stories about the firewall ripping on the hydraulic mount. Figured it would be kinda cool if I can pull this off. Should be done real soon.
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 02-05-2013, 01:02 AM   #103
dan468
dan468's Avatar
Thanks! I feel pretty fortunate to work on both these rides.
68 C-10
Build thread
Old 12-17-2013, 11:14 PM   #104
dan468
dan468's Avatar
created my clutch linkage with heim joints and custom sleeves, ditching the impala calipers and switching to camaro due to the parking brake, wiring the truck, captain fab is sending me the booster adapter and caliper adapters and I have to use a 7" booster due to room, using corvette MC, buying speed bleeders for all 4 corners Alan Grove components is providing the accessories brackets, bought a shim kit to dial down the power steering pump pressure for the Mustang rack and pinion, using a holley red fuel pump to deliver gas, rebuild a 700 Holley DP (it's small but should work for now), had to use 3/8' shim on the passenger side cab mount which I thought was unusual (any thoughts?)
68 C-10
Build thread
Old 12-17-2013, 11:52 PM   #105
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Very cool build..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 04-05-2014, 02:04 PM   #106
kvn1011
Kvn1011
kvn1011's Avatar
nice!
kvn1011 is offline   Reply With Quote
Old 04-16-2014, 11:00 PM   #107
dan468
dan468's Avatar
Thanks! Slowest build ever. Working on the brake lines now
68 C-10
Build thread
Old 08-07-2014, 07:39 AM   #108
chefcorymac
Did you ever figure out how to use your original clutch with the t-56?
chefcorymac is offline   Reply With Quote
Old 08-07-2014, 09:50 AM   #109
dan468
dan468's Avatar
Yes, the Z bar moved due to 2 things, the height change in the motor mounts and the new ball mount location in the 454. I cut one arm off the Z bar and repositioned it or "re clocked" it, made the new frame mount for the Z bar as part of the PORTERBUILT shock mount, then made new connecting linkage for whole set up. I mocked it up with all-thread and heim joints to get the clutch actuating and will replace with cleaner linkage down the road.
68 C-10
Build thread
Old 08-07-2014, 11:59 PM   #110
gdavis
gdavis's Avatar
You must have a chrome shop near by. look sweet
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 08-08-2014, 12:51 AM   #111
dan468
dan468's Avatar
Thank you
68 C-10
Build thread
Old 06-13-2017, 09:32 AM   #112
Hart_Rod
Hart_Rod's Avatar
bump
Hart_Rod is offline   Reply With Quote
