Hey guys, Im new here but i always find myself here looking for answers. So here's my problem and i haven't seen anyone with a similar issue:
My front left signal light is dim, but will blink full speed in Park and while driving. However in Drive, at a stop, it will begin to blink slowly and then stop blinking all together until i begin moving again. It is only this one light, all the others are great. I recently added rear LEDs so i understand that without the rear left hand bulb, the left side cannot trip the flasher, but i dont think this is a flasher issue. I moved the ground of the troubled light to a new spit and it worked for two days then went back to the same pattern. The wires are brown, which goes to the park light, purple which goes to Narnia, and blue which goes to Mordor. And i have no idea which one could be the problem. Any ideas guys? Posted via Mobile Device |
I am a Referee of life.
Re: Need Signal Light Help!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#3 | |
Active Member
![]() Join Date: Jul 2007
Sounds like a good bug... Is it only the left signal light that does this? Possibilities are a defective bulb, rusted or or bad contacts in bulb housing or weak grounds in the truck. First thing I would check is the alternator voltage to the battery at idle while in park then in drive with the parking brake set and wheels chocked or someone standing on the brakes. Voltage should be at least 13.5 vdc or better. Then maybe trace back the wires and check for any corrosion on the connections.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Yea its just that one light. The others are bright and responsive. I've changed bulbs too and no difference. The contacts look good so im thinking a ground but im no electrician by any means.
I have had this problem and on mine it was the socket itself where it is pressed into the housing was bad to test this take a jumper cable and clamp it to the socket housing itself [not the whole light housing] and see what happens. It can be fixed by soldering the socket to the housing assembly or by replacing the light assembly. Hope this helps
Fuzzy |
Thanks guys. I'll look into it further when i gets chance. I appreciate your help.
Tags |
blinker, dim, front light, light, signal |
