Old 02-07-2013, 09:52 PM   #1
frankyjoet
Smile power booster question
I changed the rear brakes to disc, i now have 4 disc wheels. my 73 gmc truck brakes need to be bled. When i tried to bleed them i hear an air noise from the power booster rod. now since i replaced all brake rotors and calipers, i assume or think that there is air in the brake lines. the first set you do is the rear, then alternate between the front, is this correct? i read from a good source that if the brake pedal is HARD, then the booster is bad. Also a little noise is normal. My ? is the booster ok? If so i can bleed alll the brakes. Thanks for any help.
frankyjoet is offline   Reply With Quote
Old 02-07-2013, 10:39 PM   #2
Duster
Duster's Avatar
Re: power booster question
Is the truck running when it makes the noise?
When I bleed brakes, I do the old timer "gravity bleed" method of opening the master, and cracking all the bleeds open with mason jars and surgical tubing to catch the run off. It works like a charm, and insures you have all new fluid through your lines with out air. It takes a couple hours to do though. You just keep feeding the master untill clean fluid starts coming out of all calipers. Then tighten them down and you have airless lines.
Duster is offline   Reply With Quote
