02-09-2013, 08:06 PM | #1 |
1 ton rears
Does any body know if 3/4 Ton front suspension will work with a 1 Ton front? I have heard one tons have higher purches than 3/4 tons my main concern is will it sit level and are the u joints the same?
1967 gmc 4x4 factory air factory buckets 1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne |
02-10-2013, 10:41 AM | #2 |
Re: 1 ton rears
i believe the 1 ton frames are taller.. but im sure it can be done
'82 c10 shortbed drag truck '82 GMC 3500 Dually DD scrap truck '55 Chevy 210 4 door sled '65 VW Bug Rat Rod |
02-10-2013, 03:59 PM | #3 |
Re: 1 ton rears
Is this for your '85 High Sierra? Yes,the suspension will work,bolt-in job. The Dana 60 (1t) front axle housing is larger than the 10-bolt (1/2-3/4t) and makes the same truck sit up an inch higher. The u-joints are larger and you can either use conversion u-joints,get the bigger yoke made onto your driveshaft,or use a K/30 driveshaft
02-10-2013, 08:00 PM | #4 |
Re: 1 ton rears
Yes it's for the high sierra, I want to get something a little bigger because the 3/4 Ton front looks about the same as a 1/2 ton Jason on blue hill told me the purches were taller on 1 tons so I wanted to ask about the driveshafts and suspension. It has the heavy duty 3/4 Ton in the rear, I think is about the same as a 1 ton rear right? Thanks for the help
02-11-2013, 12:55 AM | #5 |
Chevy Enthusiast
Re: 1 ton rears
You should have a 14 bolt full floater in the rear and if it has 13" drums then it is basically the same as one out of a 1 ton swr. The only difference is the 1 tons rear spring perches (and hangers on the frame) are a few inches narrower.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
02-11-2013, 01:36 AM | #6 |
At the body shop.
Re: 1 ton rears
One ton spring hangers are narrower than 3/4 tons.
" That didnt make it any newer " " Dont antique the equipment " |
