Old 02-09-2013, 09:02 PM   #1
LSUMurse
LSUMurse's Avatar
So, Rosie leans...
Well, the title says most of it. She leans to the driver's side. It looks to be about a one inch difference between the passenger and driver's side. It is throughout the whole side.
Where do I start looking to determine the issue?
She's a '68 LWB 1/2 ton stepside, if that matters.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 02-09-2013, 10:18 PM   #2
hayhauler71
hayhauler71's Avatar
Re: So, Rosie leans...
I measure the spring height of all 4 springs as it sits on level ground [compressed spring height ] to check for spring sag. Do not rely on measuring top of fender to ground because you may have bad cab to frame mounts. If the front springs are close to each others and the rears are close start checking cab mounts
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 02-09-2013, 10:20 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My guess is sagging driver's side springs, and possibly worn out suspension bushings. At 45 years old, who knows how much of its life was spent with a driver and no passenger.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-09-2013, 11:01 PM   #4
LSUMurse
LSUMurse's Avatar
If I need to replace the springs, can I replace them with 3/4 ton springs? I will eventually tow a camper or have a slide in camper. It's currently a stock 1/2 ton.
