#6951 |
Re: What did you do to your truck today?
Looks good Chad..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
#6952 |
Got the holes drill for my '60 Hood bird
http://s1299.photobucket.com/user/jb...23904108567829 |
#6953 |
![]() Join Date: Sep 2011
Very nice! Made an awesome looking hood, even better.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
#6954 |
in the middle picture, I can't help but think of the batmobile.
#6955 |
I took the cab off the frame and go the frame all stripped down. Off to the galvanizer today and then powder coating tomorrow. I love the the perks of being and autocad guy for a steel manufacturer.
1964 Chevrolet C-10 SWB Fort Worth, TX |
#6956 |
Got a couple of things done today.
Installed my TA Performance rear end girdle on my rebuilt differential with 3:73 gears and Eaton Posi-Trac. I had to bend the Porter Built Trac bar to make it fit. |
#6957 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
That looks awesome good job.......
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
#6958 |
I also got back my new dash panel and bezels to fit Dakota Digital gauges from a 1964 GTO.
#6959 |
I bought my project low and go a LSA Supercharged 6.2 Ltr Caddy powerplant backed up by a 6 speed automatic......let the games begin
#6960 |
Senior Enthusiast
Wow that girdle makes the rear end look very businesslike! And the gauges are both beautiful and unique. Nice work.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6961 |
Senior Enthusiast
Yesterday I replaced my dead compressor and today I pulled the snow tires off the front and reinstalled the five spokes. Hopefully the rears will get swapped tomorrow after I have a nail puncture patched.
#6962 | |
The 60-66 GMC/Pontiac guy....
I can't find much for our GMC's and gauges are one of those things. I did order my KP Watts link for one of the 63's... Looking to make it handle.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#6963 |
Moderator
![]() Join Date: Dec 2012
Brought my truck home! It was shipped up to the Canada/US border from Arkansas, and I trailered it back to my place. It is FILTHY. Completely covered in road sand, they must have run into some weather on the way. Now the fun begins!
![]() ![]() In the daylight, pretty dirty. ![]() I think I will need new bed wood! ![]() Last edited by jayoldschool; 02-13-2013 at 10:53 PM. |
#6964 |
OPPS! Dash panel and bezels is what I am wondering about.
#6965 |
I created a file in Adobe Illustrator file ( a graphics program) matching the Dakota Digital gauge set and then had a sign shop laser cut the flat dash panel. I had a friend machine the bezels to fit the openings.
The gauges are meant for a 1964-67 Pontiac GTO, Lemans, Tempest VHX Instruments VHX-64P-GTO in carbon fibre with red numbers and lights. The nice thing about the gauges are that they are all one unit and you run just 1 CAT5 wire from the gauges to a control box that mounts down by the fuse panel. I cut the centre section out of a stock gauge panel just leaving the outer trim ring. The 4 gauges are all together in one module which made it really easy to fit into the opening in the dash. Other then cutting up the original gauge panel which was damaged anyways by the previous owner, there was no other cutting. |
#6966 |
Bought a stud welder...finally!
I got a kickin' deal from someone who bought it, used it for 5 pins and then never touched it again. Now, I can get the hood smoothed out. Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#6967 |
Hey jayoldschool,where abouts in ontario are you?
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#6968 |
changed out my universal joint on rear from the crazy joint,and put gears in front hub now I have front wheel drive till I can get a pinion yoke....
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#6969 |
Steven, Best tool I ever bought, although "I" did not use it, the guys in the pics used the tool at $25.00 per hr. to get the dents out. BTW the cab went under 12 feet of water. BUT if you get the harbor freight like I did, you will replace the vicegrip tool quick.
#6970 |
Moderator
#6971 |
Got all my brakes finished. Replaced all the hardware except the backing plates and lines. Shoes, hardware kits, drums, wheel cylinders, and master cylinder. I also added self adjuster mechanisms to all four wheels.
I better not feel my foot hit the floor board again. lol |
#6972 | |
Being poor is the mother of invention. ![]() Steven
#6973 |
There are quite a few of us here in Ontariariario, maybe we should start an Ontario C10 club/association...
#6974 |
I welded a nut(1/2 fine thread on mine) to the vise grips and screwed in the slide hammer. I can unscrew it and use the other attachments. I don't have a stud gun. I tack welded 8d nails to the sheet metal. A little slower that a stud gun but it works just fine.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
#6975 |
I bolted my new tag on yesterday.
Only the 2nd tag it's had since I bought it almost 10 years ago... yikes! I've had it that long? -W |
