Old 02-10-2013, 11:06 PM   #1
Nitschke
Nitschke's Avatar
8 lug to 5 lug / leaf to trailing arm.... Help please
~72 Chevy Truck~
Motor: LY6 6.0 Liter
Trans: 6L80E
Still under construction
Nitschke is offline   Reply With Quote
Old 02-11-2013, 12:05 AM   #2
Nitschke
Nitschke's Avatar
Re: 8 lug to 5 lug / leaf to trailing arm.... Help please
Its a 3/4 ton 8 lug leaf spring truck 411 Dana 60 rear. I am converting it to 5 lug trailing arm setup. I've already cut the frame for short bed and it is getting a No Limits rack and pinion. So im wanting to know how to make this all work? Full guidance woud be awesome. I was given a 75 chevy van 5 lug 3/4 ton 411 open diff rear for parts it has brand new brakes, bearings, ball joints, spindles, $900 tires and aluminum radiator.
I will start a build thread soon! If someone wants to fallow.
~72 Chevy Truck~
Trans: 6L80E
Old 02-11-2013, 12:58 AM   #3
tinydb84
tinydb84's Avatar
Porterbuilt has a trailing arm set up that would bolt right in
Old 02-11-2013, 01:59 AM   #4
Nitschke
Nitschke's Avatar
Thank you. Nice stuff but to much $$$$. I dont have that kind of money to spend on it right now. Im wondering what will work from the 75 van in my conversion and what ells ill need to get. I was thinking i would get the arms from a long bed and shorten them my self. Cuz they are cheap and all over.
~72 Chevy Truck~
Trans: 6L80E
Old 02-11-2013, 03:34 AM   #5
tinydb84
tinydb84's Avatar
Someone on here did a write up on how to make their own arms...Maybe someone has a link? Or you can search for it
Old 02-11-2013, 09:28 AM   #6
SCOTI
SCOTI's Avatar
Long & short wheel base use the same length truck arms. The difference is where the x-member is mounted in the frame.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-11-2013, 10:27 AM   #7
Nitschke
Nitschke's Avatar
That would be great ill try to find it. Thanks
Good to know thanks for the info!
~72 Chevy Truck~
Trans: 6L80E
Old 02-11-2013, 11:00 AM   #8
PBFAB.COM
PBFAB.COM's Avatar
As mentioned, you can take a factory trailing arm x-member and upper shock cross member from a coil spring truck and install it in your leaf spring truck. The trailing arms will bolt right in also.... BUT the trailing arms are different from 3/4 ton to 1/2 ton so you will need to find some specific to the 3/4 ton application.
We understand the "budget" for sure... but we are always willing to help with information or other alternatives. Feel free to give us a call if you would like to discuss the swap.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-11-2013, 11:50 PM   #9
Nitschke
Nitschke's Avatar
Smile Re: 8 lug to 5 lug / leaf to trailing arm.... Help please
Nate
Thank you very much for the info offer i will probably take you up on that at some point soon.
What are the differences in the arms?
~72 Chevy Truck~
Trans: 6L80E
Old 02-12-2013, 09:33 AM   #10
SCOTI
SCOTI's Avatar
Factory 3/4 ton arms are partially plated on the top & bottom for additional strength.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
