Old 02-11-2013, 10:12 AM   #1
UATahoe
Need some help on high pitch whistling noise when fan is on
Ok. So i just recently finished putting new weatherstripping everywhere in my 87 pickup. Now when i turn on the fan i get a realy high pitch whistling noise. Here is the strange part though. If i put it on max AC, it is as quiet as can be on every fan speed and not a single problem. Hear nothing. But on any of the other remaining settings (reg ac, vent, heat, defrost) there is a really loud whistling noise on all fan settings except the lowest setting. And you can almost feel the pressure effecting your head. I am stumped on this one. Any help????
UATahoe is offline   Reply With Quote
Old 02-11-2013, 10:16 AM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: Need some help on high pitch whistling noise when fan is on
Believe it has something to do with pressurizing the cab, when on the ac settings it cycles through the system and not through the cab. When on the vent and heat it must move the dampers to become paritially open and causing the whistling.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 02-11-2013, 10:26 AM   #3
UATahoe
Well, on the max ac i hear nothing. On the reg ac i hear the same noise as on the heat vent and defrost settings.
Old 02-11-2013, 11:07 AM   #4
James McClure
One shot, one kill.
UA. "Max" is the old "recirc" setting. This recirculates air in the cab volume for volume so no pressure\vacuum will exist. At ANY of the other settings, fresh air is drawn into the cab. This creates a high pessure area inside the cab as related to outside ambient atmospheric pressure, hence the whistle. Finding it isn't going to be easy, but using a stethescope with just an open end should help. Run the truck and put the controls to duplicate the noise. Using thee open end of the scope, trace EVERY gasketed area until you track it down. When I redid my truck the new gaskets made it almost impossible to shut the doors without opening a window. I had wind noises also. Found mine to be in the vent windows, they wouldn't close all the way, gaskets would turn in just a bit. A little silicone spray fixed that. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 02-11-2013, 11:18 AM   #5
UATahoe
Jim, thanks! The vent window seals were reokaced on mine also and they sound awful even though they are new. I will try to track it down and see whats up. Sounds like it will be fun. LOL I am tempted to seal off the vent windows from the outside and just keep them shut. The wind noise from them is just awful.
Old 02-11-2013, 11:23 AM   #6
Keith Seymore
Keith Seymore's Avatar
Yep - you are pressurizing the cab. Rolling the window down just a skotch will make it go away.
You don't hear it on MAX because it is recirculating the air rather than drawing from the outside.
And - the windnoise from the vent window is, in fact, awful. Even when new.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-11-2013, 11:27 AM   #7
UATahoe
LOL no doubt. I am just giving up on them. Would a bead of clear silicon around the outside edges seal it off well enough to get rid of the noise?
So far, my solution has been to barely crack the back slider. I may just stick with that for now.
Old 02-11-2013, 12:30 PM   #8
Keith Seymore
One of the things you could try is taking the Pressure Relief Valve out of the bottom of the door; that might provide enough airflow to make the whistle go away. (Then you run the risk of cold air flowing back in, depending on the climate where you live).
But I just touch the side window, rolling it down just enough to make the whistle stop.
K
1979-1986
1986 - 2019
Old 02-11-2013, 01:40 PM   #9
UATahoe
Awesome. Thanks Keith! What does the valve look like? I am not familiar with it. I live in Alabama so cold air wouldnt be a problem. Hot maybe but i might try it out to see.
Old 02-11-2013, 02:01 PM   #10
Keith Seymore
It mounts behind the louvers in the door, one screw on each end.
It's a small plastic frame with little rubber flaps that hang down.
It may not make much of a difference in terms of air flow (outbound) but could put you over the edge.
K
1979-1986
1986 - 2019
