02-11-2013, 12:40 PM | #1 |
1960 C10 Budget Front Disc Kit???
I found this kit this weekend and wondered if anyone else here has used it? My truck is a torsion bar front end so I can't just upgrade the A-arms and spindles to a 73-87 like a lot of you guys can-- I have to swap the entire cross-member and I'm having a hell of a time locating one. I thought this might be a good alternative. Thoughts?
http://www.classicparts.com/1960-63-.../#.URkeNx1JM1I |
02-11-2013, 03:58 PM | #2 |
Re: 1960 C10 Budget Front Disc Kit???
I realize I'd have the car 5-bolt pattern, which is unfortunate. But this would upgrade those terrible ball bearings to roller bearings and parts are easily accessible.
02-12-2013, 04:47 PM | #3 |
Btt
02-12-2013, 11:14 PM | #4 |
You could do what I did only I bought the whole power disc brake kit from ece. Only you could buy the spindle that would let you put on 73 to 87 stock disc and calipers.
02-12-2013, 11:24 PM | #5 |
I would NOT use that kit. The rotors you will be required to run are NOT adequately sized to safely stop a full size truck.
02-12-2013, 11:33 PM | #6 |
I hear you on the price of the bearings !!!
As you know for us 60-62 guys disc brakes are not as easy to do. Yes you can swap out the front cross member, or go with disc brake spindles ( about 200-300) or you can try those adaptors. What ever way you decide to go you would still need new or rebuilt calipers,new rotors,brake hose and a disc master cylinder. You may also run into some problems with a booster if your truck is a stick. I went with the spindels ,6lug rotors from Mcgauhy. I purchased the calipers,hoses,bearings and seals from a local parts house ( ask for 1972 c10 parts) I got new balljoints and an aluminum master from CPP.I am going to use a hydroboost instead of a vacum booster. All I need to do is find time to install . The addaptors seem easy enough to install but may be a bit small.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
02-13-2013, 12:08 PM | #7 |
gbrown I had alot of decisions to make on my 60 and like slepysal says about the cost of the bearings its crazy..So I went with CPP and everything was bolt on and I was done with it!!!
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
02-13-2013, 12:27 PM | #8 | |
I've decided against this kit anyways, strictly based upon the bolt pattern. |
02-13-2013, 12:45 PM | #9 |
Well I own a '69 Chevelle and I doubt its heavier than my C10, but I could be wrong about that! All I know is that the rotors & bearings on the Chevelle are substantially smaller than the rotors on the C10. For what its worth.
02-13-2013, 01:47 PM | #10 |
73-87 C10 - 1 1'4" rotors - even if you have to buy a basket case to get the clip - part it out / scrap it and save what you need.
Aftermaket 6 lugs rotors are available everywhere and it's by far the cleanest simplest overall effective upgrade going. Just did it to my 62 C10 using all 78 2wd burb parts. Check the local CL on a daily basis, hit the local yards, and do something else that will need to be done for the upgrade while you're searching and before you know it the pieces are in place. Good luck! rg |
02-13-2013, 01:53 PM | #11 | |
02-13-2013, 02:06 PM | #12 | |
Grab the center link, tie-rods, idler, pitman, if it's worth it only. IF the stuff is junk let it go be junk somewhere else but you can still document things with some pics and measurements. Center link should be good for sure. Sway bar too. Brackets can me made to work even with the early box frame if you use long bolts or do cut outs for frame mounts. I did get the booster & master and it's the 6 bolt welded stud bracket typical of the light trucks in this era, so I think it will work with some drilling and perhaps a plate over the stock master's location to reinforce as well as seal things off. Proportioning valve is a possibility too. Just check mileage, apparent wear issues (i.e. rusty as heck, damaged, or whatever). When I bought my 78 parts, the truck had been in a garage for 20 years and everything was fairly clean, so I snagged it ALL for $250. These trucks are the "Model T's" of our era - just be patient if this isn't the one you will no doubt find another. Best of luck & keep us posted. rg |
02-13-2013, 03:07 PM | #13 |
67-72 parts collector,…
The quickest and easiest would be to buy 60-62 disc brake spindles,... like mentioned above.
If the entire front end needs to be rebuilt,... I would swap the crossmember for the 73-87 version.
02-13-2013, 08:49 PM | #14 |
DoobieBro,
How were you able to convert yours? We have a 61, would like to convert to a 6 lug rotor. (Want to keep our current wheels) Hope to do this without change the crossmember. Thanks, Glenn
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
02-13-2013, 09:56 PM | #15 | |
I hope DoobieBro chimes in, but in case he doesn't, I believe he bought something like this: http://www.classicperform.com/Store/...6062SWBK-5.htm or perhaps this: http://www.classicperform.com/Store/...062SWBK5OE.htm Both nice options if you've got the $$$. Although I do believe there could be clearance issues with a stock wheel... |
02-14-2013, 12:46 AM | #16 |
Senior Enthusiast
If all you want to do is get rid of the expensive ball bearings, post #5 on the following thread may prove helpful:
http://67-72chevytrucks.com/vboard/s...wheel+bearings
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-14-2013, 02:22 AM | #17 |
gbrown is correct.. I pretty much rebuilt the original front suspension parts and ordered 6 lug 2 1/2" drop spindle disc brake wheel kit from CPP 5 years ago - Part # 6062SWBK-6. I have rear coil springs 4" drop and also bought the brake booster kit Very satisfied with the products and they warranty the parts lifetime.. I have the older version but I believe there are little diff from the new stuff they carry.. Also if you are using the OG rims they will NOT work with disc brake conversion. here are sum more pics..
02-14-2013, 11:11 AM | #18 |
lolife is always correct.....
