Old 02-12-2013, 08:49 PM   #1
62 Barnfind
62 Barnfind's Avatar
Replacing a front suspension on a 62
My neighbor has a 86 step side he is going to scrap and told me I could have anything if I want it. I already took the tailgate and felt a little guilty for doing that. I was wondering if I took the front suspension, hydro boost and Master cylinder could I get six lug rotors for that year 1/2 ton? I am trying not to switch the rear end or re drilled I will. He also has a 350 trans and if i'm not sure if it will bolt up to a 235. Many of you have done both mods, any Advice would help me?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 02-12-2013, 09:29 PM   #2
62 Barnfind
Re: Replacing a front suspension on a 62
Sorry I just noticed my grammar. If I have to re drill the rear axel I will do it.
John Z
62 Barnfind
Old 02-13-2013, 12:54 AM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
You can get 6 lugs rotors.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-13-2013, 12:58 AM   #4
Captainfab
60-66 Nut
Yes you can use all of those parts on your truck. The TH350 will not bolt up to a 235 without an adapter. The aftermarket 6 lug rotors will only work with the spindles for the 1.250" rotors. That '86 could have either the 1" rotors or the 1.250" rotors.
Old 02-13-2013, 01:05 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I don’t have time tonight to offer a more thorough answer, but the following threads should point you in the right direction. The first has to do with the front suspension swap on a 60-62 and the 2nd has to do with disc brake conversion options:
http://67-72chevytrucks.com/vboard/s...d.php?t=366828
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-13-2013, 06:39 AM   #6
62 Barnfind
Thanks for the advice. I'm still toying with the idea on switching the front end out. One day i'm for and another i'm not. It still will add a little more cost and time to my build. Not so much about more money because I think in the long run i will do the swap but the time. I will be deploying in June and would like to complete my build or get close. marke01 how long did yours take?
John Z
62 Barnfind
