Old 02-16-2013, 02:14 PM   #1
mike805
73-80 fender height?
I have an 89 crew cab dually that is bagged and body dropped. It's going in for paint and I had the body shop convert it to a 77 front end. Anyway, the body shop feels that the 77 hood won't clear the top of my motor (due to the body drop). I figured it wouldn't be a problem since the 73-80 fenders have no slope and the old (newer style) hood and fenders cleared (barely). Are the older fenders not as tall? Any suggestion? Trying to avoid a cowl hood because I'm golfing with a moulding on, original style look. Thanks, Mike
mike805 is offline   Reply With Quote
Old 02-16-2013, 04:32 PM   #2
74 stepside
74 stepside's Avatar
Re: 73-80 fender height?
You will have slightly more room with the older front end. Make sure you have the correct body bushings under the core support. If the bodyshop still cant figure it out, go to a different bodyshop. Because it sounds like they dont know what they are doing.
74 stepside is offline   Reply With Quote
Old 02-16-2013, 06:16 PM   #3
mike805
He pointed out the mounts for the core support yesterday. They've been moved up to to z' ing the frame, so it looks like there's not much room for a bushing. He was talking about cutting the mint off and moving it down, but it worked on the other front end so I don't see why it wouldn't work on the 77, unless the mounts and bushings are completely different.
Old 02-16-2013, 07:36 PM   #4
74 stepside
Whether you have a Zd frame or not, you should have room for the bushing under the core support. Your core support is the key factor in making the fenders and hood line up.
Old 02-22-2013, 01:03 AM   #5
mike805
So I've read on other posts that since I have the newer style frame, I need to move the core support mounts. I have 81-87 cab bushings, do I use the same for the 77 core support or the older bushings?
Old 02-22-2013, 03:59 AM   #6
74 stepside
Really dont know. I thought the mounts were in the same location reguardless if 73-80 or 81-91. I'd try the correct bushings to the older front end.
