Old 02-17-2013, 12:11 PM   #326
jkeating1
jkeating1's Avatar
Re: She's a ton of fun (dually build on air)
I guess I didn't realize you had the Dropmember also.
The 73-87 bagged dually guys run dually hubs with narrowed arms, or 1-ton single wheel hubs with "lengthened" arms.
I'm not sure if the Dropmembers narrowed track width will be enough.
The stock set-up won't tuck.
This is why I love this board! I like the idea of longer arms and single wheel hubs instead of that long space between the bearings and the hub flange. Not to mention the unsprung weight of that one-ton hub!
Lo, when you say "the stock set-up won't work"---do you mean with the semi wheels (like the pic, and like Rus will use)? In other words; mine is a '72 C20, I will run stock 16" steel one-ton wheels, shorter-than-stock tires (IDK the height yet), stock subframe, PB lengthened arms & bags, & C20 or C30 SW hubs. If I (I mean Nate) get the hub-to-hub dimension right, I should be good to go, huh? I know it won't lay frame, but at a lowish ride height, it will prob be driveable, or will it?
Hope I didnt get off into hijack territory Rus, but like you, I love it when I find a man who knows!
JK
JK
jkeating1 is offline   Reply With Quote
Old 02-17-2013, 12:28 PM   #327
lolife99
67-72 parts collector,…
lolife99's Avatar
JK
You might be ok with 16" wheels.
The PB arms are for the guys spending the CA$H to run semi wheels, and lay frame.
In your case,... I would just run dually hubs and stock a-arms with bags and cups.
There are ton's of pics on the internet.
I know people use this forum to answer specific questions,... but if you look around, you can find the exact truck you are building.
Example:
http://67-72chevytrucks.com/vboard/s...d.php?t=245096
Use Google Images.http://www.google.com/search?hl=en&s...w=1024&bih=485
Like these,...
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 02-17-2013, 01:24 PM   #328
Rusbuilt
Rusbuilt's Avatar
Have you mocked up your front end, with the wheels you will be using, yet?
As in this member's truck.
(I would ask Nate what he thinks)
Yeah I need to give him a call tomorrow. I am actually looking at a set of wheels tomorrow. I hope to be able to do a mock up on paper as in... knowing the wheel offset, thickness of the 8to10 lug adapter and the track width with from hub to hub vs the width from inside of fender to inside of fender. Hopefully I can get it close. Who knows maybe I'll talk to Nate and he will know exactly what I should do! Thanks for your help Keith!
I've been meaning to ask you--what's the difference between a 3500 and a 4500? And what is the 3500 in?
Here's a 3500 for that appears to be much less $ than 4500's
http://www.ebay.com/itm/CHEVROLET-19...5ac08f&vxp=mtr
JK
The 3500 came in the half tons and the 4500 came in the 3/4-1 tons. If I understand correctly the 4500 has a granny gear and I'm not really looking for that so I want to go with the 3500. If I pull anything it won't be much so I think it will serve me well!
Rusbuilt is offline   Reply With Quote
Old 02-18-2013, 12:22 AM   #329
502ms
502ms's Avatar
I could be mistaken, but I think the 3500 has the granny first gear as well (I think they are both 5.34 or something crazy like that)
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-18-2013, 09:45 AM   #330
Rusbuilt
Rusbuilt's Avatar
I'm not 100% on the granny gear thing thats just what I was told. Once I have my suspension down I'll really start to look into it.
Old 02-18-2013, 03:36 PM   #331
MattSt
MattSt's Avatar
GM Specs:
NV3500 gears:
1___2___3____4___5___R
3.49 2.16 1.40 1.00 0.73 3.55
NV 4500 gears:
1______________________2____3___4___5___R
6.34 (1993) 5.61 (1994 on) 3.44 1.71 1.00 0.73 6.34 (1993) 5.61 (1994 on)
Towing with a NV3500 is going to be hard on the clutch if you are decently heavy. I have an NV4500 going into my 1970 GMC. I plan to tow with it so I wanted the deeper first gear to get 20k worth of steel rolling off the light. Ideally a NV5600 is what I wanted because it has better gear splits and I have towed with one a lot and love this trans. 1st 5.63 2nd 3.38 3rd 2.04 4th 1.39 5th 1.00 6th 0.73 R 5.63 But they are super spendy. Still better than an SM465. IMO
Project is looking good!
1970 GMC Custom Camper 396, A/C, Tach
1978 Chevy 1 ton 350, NV4500, D60/14 bolt (drivetrain donor for the GMC)
MattSt is offline   Reply With Quote
Old 02-18-2013, 04:03 PM   #332
RatRod68
RatRod68's Avatar
Originally Posted by MattSt View Post
GM Specs:
NV3500 gears:
NV 4500 gears:
Awesome info. I know hauling with a 465 is hell. Going up hills you might as well forget going anything over 30mph. You may hit 40 depending on your rear end gears.
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 02-18-2013, 05:24 PM   #333
shearjs
shearjs's Avatar
My '03 GMC has a NV3500 from the factory. I've read its good in its stock form for about 300-350 hp. I'm not sure what you have in store under the hood, but something to keep in mind.
shearjs is offline   Reply With Quote
Old 02-18-2013, 06:55 PM   #334
Rusbuilt
Rusbuilt's Avatar
GM Specs:
NV3500 gears:
NV 4500 gears:
Thank you for the info and the complement!
Yeah that's plenty for me, I'm keeping the 292!
Old 02-18-2013, 09:34 PM   #335
cubber
292!292!292!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 02-18-2013, 09:46 PM   #336
Rusbuilt
Rusbuilt's Avatar
UPDATE!!
I talked to the Porterbuilt fellas today and the plan is to run 1 ton spindles with the stock length arms. After the added length of the 10 lug adapter minus the monster offset of my 22" semi wheels, they should then squeeze up inside the fenders!!
I bought 4 of them today!! Hoot Hoot!
Old 02-18-2013, 09:47 PM   #337
JRANGER
JRANGER's Avatar
Sweeeet!!!!!!!!!!!!!!!!!!!!! Gonna paint them? Or keep them like that?
JRANGER is offline   Reply With Quote
Old 02-18-2013, 10:00 PM   #338
Rusbuilt
Rusbuilt's Avatar
undecided at the moment.
Old 02-18-2013, 10:20 PM   #339
cubber
I never even thought about paint! Is that even an option? They would look tough all shined up, too, though!
=MATTHEW
Old 02-18-2013, 10:29 PM   #340
JRANGER
JRANGER's Avatar
could be but i know a guy that powder coats too Not sure how much he charges though
Old 02-18-2013, 10:34 PM   #341
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Those semi wheels look sexy just sitting there!
Old 02-18-2013, 10:47 PM   #342
Rusbuilt
Rusbuilt's Avatar
Pic for you below!!
Why thank you!
Old 02-18-2013, 10:48 PM   #343
5150
C10 Club Tennessee
5150's Avatar
Powdercoat those bad boys white!!! Should be around $50 a wheel.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 02-18-2013, 11:03 PM   #344
Rusbuilt
Rusbuilt's Avatar
I like having options!
Old 02-18-2013, 11:14 PM   #345
jkeating1
jkeating1's Avatar
Originally Posted by Rusbuilt View Post
Pic for you below!!
Why thank you!
Is that your tire size, too?
JK
Old 02-18-2013, 11:16 PM   #346
Rusbuilt
Rusbuilt's Avatar
Should be close to that
Old 02-18-2013, 11:20 PM   #347
Bennett68C10
Bennett68C10's Avatar
Those wheels look awesome Rusbuilt, this truck is going to be sweet dropmembered on those Semi wheels
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-18-2013, 11:22 PM   #348
Rusbuilt
Rusbuilt's Avatar
Thanks Keith! I appreciate that!
Old 02-18-2013, 11:25 PM   #349
jkeating1
jkeating1's Avatar
Less than 28" tire height, 4.10 gear, 292 torque---I'm cool with a 3.49 first gear!
JK
Old 02-18-2013, 11:27 PM   #350
5150
C10 Club Tennessee
5150's Avatar
Is your PB stuff going to be here by March 16? No reason, just asking.
Bryan
www.gmtruckshow.com
dropmember, dually, patina, semi wheels
