Need some carb help/advice, Edelbrock 1405
Hoping some carb guru's might be able to help me out with the issue I've been having.
Just swapped my inline 6 for a Goodwrench 350. Bought a new 1405 and haven't been able to get it running right yet. The carb is sputtering out fuel at idle. Engine runs, but barely. Obviously running quite rich. I'm on my 3rd fuel pump now. Bought the first and then realized it was running too high a pressure (Edelbrock suggests 6psi max). I bought a cheapie that advertised this pressure range, only to find out it was running much higher. Out of frustration, I finally just bought the Edelbrock street pump specifically designed to run these carbs. I haven't checked the pressure on this pump yet as I don't have the right fittings in hand to run a gauge. All 3 pumps and no change. I've adjusted the floats twice, cleaned out the needle and seat each time. Each time I haven't noticed anything that would cause the flooding issue. I walked through the float adjustment with Edelbrock on the phone. Got it back together last night and no luck. Long story short, am I dealing with a bum carb here or could there be other issues? Had several friends verify I have it installed correctly and even walked through the float adjustment with me. Could a vacuum leak cause this condition? I'm far from a carb expert. Just looking for advice. Quite frustrated as I finally have her back together and my brand new carb is acting up on me!!!!
1967 C10 Stepside - "Minty" 1972 GMC 3500 - "Rojo Grande" |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Need some carb help/advice, Edelbrock 1405
See if anything here helps.
.........http://www.edelbrock.com/automotive_...ech_vids.shtml
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
what type of choke, manual or electric, see if that might be causing the probelm
#4 | |
![]() Posted via Mobile Device
Still sounds like too much fuel pressure. You may want to install a regulator to eliminate the potential issue.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#6 | |
That carb, new, should run on that engine right out of the box. Maybe needing some fine tuning, but that's all--not like you're trying to run a 1050cfm on a tiny v-8 engine! Sounds like it's time for Edelbrock to exchange carbs with you.
Sam |
Grandpa in the rustmobile...
Order a regulator from summit or the edelbrock brand fuel pump 6psi, while your waiting for the parts in the mail take the top off clean it reset the float level and rebuild it (can get rebuild kit from autostore around $25).
I would personally do the edlebrock fuel pump (did the regulator myself) its impossible to plumb it pretty with a filter regulator and the general config of the fuel port on the edelbrocks. Good luck, anywhere from 5-6psi ourghta make er happy
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
You might wanna be sure you do nothing to void your warranty.
sam |
Appreciate the replies!!
Friday afternoon I took all my "hard lines" back off so I can install my pressure gauge. Mind you this is the 4th time in a few weeks I've been doused in gasoline. Crank it over and sure enough, 6psi. Call Edelbrock again, this time I'm not as pleasant. Guy really has nothing to tell me. Frustrated, I'm about to push it back in the garage and I decide to go ahead and crank it up for grins. Mysteriously, the problem has corrected itself! Swapped plugs on saturday and did some fine tuning. She's running great! No idea what the problem was or what the fix was.
Sounds as if the needle has a spot on the viton tip which wasn't seated ,I have seen this several times in the last thirty some years I have been wrenching.
C/10 junkie
The truck knew it was either start and run or go back into the dark garage where it's lonely
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
I'm running the 1405 myself. I have since installed the electric choke kit. (I could never work the manual choke myself...)
The truck was my uncle's before he died, and my grandfather's before he died. At some point my uncle installed the 1405, but never installed a fuel filter. One day I couldn't get it to start and ended up hydro-locking my engine with gasoline! Reading up, I found the carb doesn't come with a filter and an external one must be used. Apparently a bit of debris blocked the needle valve open causing the flooding. Are you using an external filter?
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
Yeah, I have an external filter. One issue could have been that I've been swapping back and forth between fuel lines. I have the edelbrock kit that has all fittings and hard lines. But my gauge is just a hose style. Likely I could have gotten some crap in there during one of my swaps.
I will say once I swapped the plugs it was very easy to get it tuned. Truck seems to be liking the carb now. All I need is to grab some new tires and I'll start exploring outside of the neighborhood.
#15 |
RIP Mr Ron
![]() Join Date: Dec 2005
I just love a happy ending. I own 4 Edelbrock carbs (bought 2 new and 2 "like new") I haven't had any luck with any of them. I am going back to Holleys.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
