#126 |
Re: My 1952 truck.
This is the tape I use. Fibreglass does not faze it. It is called metalized tape. Plastic with thin coating of metal on it. It is transparent also. I should coat my door handles. Stuff looks as good as chrome.
Wade Last edited by SSABMUD; 02-22-2013 at 04:04 PM. |
#127 |
Re: My 1952 truck.
Question for ya SSABMUD, Did you make those stake pocket extensions?
#128 | |
Re: My 1952 truck.
Wade |
#129 |
Re: My 1952 truck.
Mind explaining how you did it? I have a stake pocket that is bent all to rat sh$t. With all the curves and radius's, looks tough to replicate.
#130 |
Re: My 1952 truck.
Just go buy some 3/8" rod, cut and bend to the shape you want, weld the rod pieces to the existing pocket. Then cut flat 18 gauge pieces to fill in the holes. Flush on the sides and recessed on the top.
Wade |
#131 |
![]() Join Date: Jul 2011
Re: My 1952 truck.
Looking good. Hope the back holds up!
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
#132 |
Re: My 1952 truck.
Thanks for the steps but how are you replicating the radius between on the top piece that it welded underneith to the 3/8" rod?
#133 |
Re: My 1952 truck.
Are you riveting the metal brackets to the glass? Or just grinding up the mating surfaces and glassing them? More pics of the console progress! Love it!!!
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
#134 | |
Re: My 1952 truck.
Wade |
#135 |
Re: My 1952 truck.
Little more progress.
Wade |
#136 |
Re: My 1952 truck.
Front mounting bracket added.
Wade |
#137 |
Re: My 1952 truck.
Inner section added to attach outer cover to.
Wade |
#138 |
Re: My 1952 truck.
Inner console tray.
Wade |
#139 |
Re: My 1952 truck.
Need to make the flange on tray and put it in. Then cover install.
Wade |
#140 |
Re: My 1952 truck.
Pop out drink holders are in and work great.
Wade |
#141 |
Re: My 1952 truck.
Put it back in truck to make sure everything fits properly. Then I need to do one final glass after console tray is done to fix small flaws before filler.
Wade |
#142 |
Re: My 1952 truck.
Sometimes you think about all the cash going into your truck, then you see a 15,000 square foot house being built! Think of his bills!
Posted via Mobile Device Posted via Mobile Device
Wade |
#143 |
Re: My 1952 truck.
Could someone explain to me why my IPhone pictures keep loading on here sideways and why I can't upload more than one photo at a time? Anyways, I think I am going to ditch this shifter boot ring but keep the led shift light.
Wade |
#144 |
Re: My 1952 truck.
Looking real good.
Kim |
#145 |
Re: My 1952 truck.
ssabmud, coming along nice. yeah a 15k sq ft house ahhh no thanks on that one. Cost of wood is ridiculous these days.
As for your pics. What you can try, (seeings you probably don't have a program on your computer to edit them) is open up your photos on your iphone then tap on a photo once. You will see in the upper right corner and edit button, tap that, then you will see a rotation arrow and you can rotate your images, then hit save. then try uploading it. Also are you uploading from your phone or computer?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#146 | |
Re: My 1952 truck.
Wade |
#147 |
Re: My 1952 truck.
maybe try rotating the picture the "opposite" way you want it on your phone and upload it, maybe it will rotate it to the way you really want it. worth a try, never uploaded from my phone so I dunno. Computer much easier.
#148 |
Re: My 1952 truck.
WOW & WOW, Wade my man nice build, love the headers, and the fabrication work inside the cab, amazing. Plzzz keep the photos coming.
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#149 | |
Re: My 1952 truck.
![]() Posted via Mobile Device
Wade |
#150 |
Re: My 1952 truck.
Great job on the console!
