Old 02-22-2013, 09:26 PM   #1
damianbryand
Will this work?
In your opinion, is this a decent disc brake set up for a conversion on a 68 c10? This is on a 72. I can't figure out how to upload more pics at one time.
damianbryand is offline   Reply With Quote
Old 02-22-2013, 09:29 PM   #2
damianbryand
Re: Will this work?
Old 02-22-2013, 09:35 PM   #3
71swb4x4
71swb4x4's Avatar
Re: Will this work?
It will work but you are going to have to replace the calipers and rotors on that setup since they are so "weathered".
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-22-2013, 09:37 PM   #4
cdowns
cdowns's Avatar
Re: Will this work?
it looks like a good start really depends how much? havin that motor there is a negative to have to work around
those rotors might actually be a lot better than any thing you could buy new if they r not all gouged up a power wash to clean the mud out of the cooling holes a light coat of por15 and a macine shop light cut to true them// if they are within tolerances better than any chinese crap at the store nowadays
the calipers? junk cores at the best
Old 02-22-2013, 09:47 PM   #5
buckskins4ever
buckskins4ever's Avatar
Re: Will this work?
Definitely a good start....you will need new inner and outer tie rod ends, new rotors, calipers and pads......but if you take everything you see and can get to, you will be very happy when completed.
buckskins4ever is offline   Reply With Quote
Old 02-22-2013, 09:56 PM   #6
damianbryand
Re: Will this work?
Ok I'm going to get a quote tomorrow. The motor isn't bolted down. I actually moved it to get a decent pic.
Old 02-22-2013, 10:00 PM   #7
buckskins4ever
Re: Will this work?
Damian, if the guy will let you......try to buy the who front frame assembly. Just to make it easy on your change over. If you get lucky and have a torch or really good sawzall.......cut the frame just in front of the cab and take it all as one piece.
Good Luck
Old 02-22-2013, 10:05 PM   #8
TexasSteve
TexasSteve's Avatar
Re: Will this work?
Good Luck
No. Don't sacrifice a frame just to get parts off of it then throw away the frame piece you cut off. That is ruining an entire frame for the sake of just a few pieces.
2001 Yukon Factory Grey Metallic~2" DJM Key front drop/3" DJM Rear Springs~stock 16" chrome steel wheels~5.3/4L60E~Volante CAI w/under bumper air scoop~Magnaflow 10426 Bullet muffler~DDM LED all exterior lighting/55w-5000k HID Hi/Low/35w Fog
TexasSteve is offline   Reply With Quote
Old 02-22-2013, 10:29 PM   #9
damianbryand
Re: Will this work?
The frame is cut out in the rear so it's really useless. So what will I need for the conversion?
Old 02-22-2013, 10:33 PM   #10
damianbryand
Re: Will this work?
Old 02-22-2013, 10:39 PM   #11
buckskins4ever
Re: Will this work?
we did the same thing to a 67 we did a few months ago (before our wonderful snow started coming) It was easiest to just unbolt everything and switch over. Everything isnt needed per say, but you are sure to have exact fit when done.
Old 02-22-2013, 10:42 PM   #12
buckskins4ever
Re: Will this work?
Steve, we have so many junker long boxes sitting around here its pathetic. We build a few of these a year and everyone wants a shorty. so we gonna be cutting the frame a little anyways. But I would agree if you have a good frame and a need for it....dont cut it.
Old 02-22-2013, 10:47 PM   #13
damianbryand
Re: Will this work?
So what all do I need? The a arms and rotors along with the calipers?
Old 02-22-2013, 10:49 PM   #14
damianbryand
Re: Will this work?
Oh btw here's a pic of my project. Pretty good shape... My first build.
Old 02-22-2013, 11:01 PM   #15
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Will this work?
Get the whole magilla from the master cylinder (plus the booster) on down. Get the brake pushrod as well, just to make sure you have a less painful swap. The proportioning valve is different for drum Vs disc, and the lines are a different size, IIRC. This is one upgrade I'll be making to mine, bedamned to being true to the SPID. Disc brakes have it ALL over drums. I've done it in the past with cars, trucks aren't that different.
Looks like you're makin' 'er nice!
~Steven
Simi Valley, CA
Old 02-24-2013, 01:45 AM   #16
425HP409
425hp409
425HP409's Avatar
Re: Will this work?
You will need the spindles with rotors and calipers and the complete tie rod assemblies. The tie rod ends on the 71-72 disc brake set up are larger than the drum brake ones. Be sure to get the center link along with the tie rod ends. If you replace the tie rod ends, be sure to get ones for a 71-72 disc brake truck.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
