85 C10 4 Link 9inch Z Frame Air T56 Build
Figured was about time I started a build thread before i'm finished. It's an 85 C10 I have had for a while. Was a long bed I shortened about 6 months ago. Been collecting parts for a couple years.
I will bring this up to current state quickly with alot of pictures. I work on it every day so progress has been very fast. Been 3 weeks since tear down and work started. Heree we go... ![]() Last edited by wraprail; 02-24-2013 at 09:26 AM. |
Re: 85 C10 4 Link 9inch Z Frame Air T56 Build
Heres where I started this time...
![]() Fast forward to teardown complete. I don't have a frame table or jig so my garage floor will have to do. I welded stands onto my frame (at my projected ride hight) in 8 places, made the four front stands adjustable and painted around each one a mark on my garage floor so future measurments will be from same place. ![]() ![]() ![]() ![]() |
I made my frame cuts for my Z at a 20 degree angle. I figured that a 2 1/2 inch Z at 20 degrees will move the front wheels (and everything else) forward just a hair less than an inch. Also I figured it would be a stronger connection. I laid out my cuts and tacked a fence for my saw so I would have a perfectly straight cut that would need no grinding. My thinking was it would be alot easier to line up the two pieces and I was right. Piece of cake.
OK here you can see why I made the front frame "legs" or stands adjustable. They are 1 1/2 tubing with 1" pipe inside. The pipe is a very tight fit but will slide. There is a set scr
ew with 2 holes. One at ride hight and one 2 1/2 inches higher.. After cutting the frame I just removed the screw, lowered the legs and reinstalled the set screw. Now the front half is right where I needed it to weld. Wprked perfectly. ![]() |
I plated the inside of the frame on both sides then half ground my ugly ass welds on the outside.
On the front I did the same 20 degree angle cut only backwards this time. I could have just made a straight cut and removed the inch (or whatever I gained on the first cut) but I thought doing the same angle was best.. First reason was that I am not sure exactly how much wheelbase I added. I know it's less than an inch (I hope) but do not know exactly. Second reason I did not make a straight cut here was I wanted to keep the 2 bumper bolt holes intact. That way everything would line up and bolt back on. If I cut straaight and removed an inch the bumper bolt holes would go away. I cut just past the steering box mounting holes and the same place on other side.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by wraprail; 02-24-2013 at 06:05 AM. |
Looks awsome. I'm tuning in for the rest!
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
nice work bro Z looks good.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
Thanks...
So as you can see I used 2 inch X 1/4 flat bar to tie the frontr frame horns together and tied that into the factory front crossmember. |
So I already had the step notch in back. Started the 4 link.
![]() ![]() ![]() ![]() ![]() Posted via Mobile Device |
im not much into lowered stuff, but i really like the creativity of that frame fabrication/modification! very nice job!
#15 |
Bag mounts, shock mounts
#16 |
Add a little paint.
#17 |
Dakota Digital SEN-201 height sensors for DHC-2000
![]() ![]() ![]() ![]() ![]() ![]() Posted via Mobile Device |
#18 |
9 inch is from a 79 Lincoln mark 5, has single piston floating brake calipers and 3.70 r&p
Moved the battery and air tank behind the axle. ![]() ![]() ![]() ![]() ![]() Heres my water trap ....... ![]() Posted via Mobile Device |
#19 |
And my Acuair valves with Dakota Digital pressure senders.
#20 |
Had to cut the crossmember so I figured it was a good place for a driveshaft loop.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posted via Mobile Device |
#21 |
lots of progress man.... keep up the good work...
#22 |
Home Built '87
Looks great & very well documented for the rest of us to learn from!!
I'm guessing you might have done this before.... ![]()
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#23 |
Thanks. Never done this before but been thinking about it for a long time.
#24 |
Tank drain and blow off valve
Combo ![]() Posted via Mobile Device |
#25 |
looks sick dude
85 swb c10 6/6 drop 83 c10 bagged and sfbd project |
