Old 11-10-2003, 09:51 AM   #1
VTKidder
Vacuum gauge conversion kit
NOW ON EBAY.....
-- Kit --
-- Lens --
Everything needed to add a factory vacuum gauge to your truck; the backing lens for the gauges that says " VACUUM " (GM#6458969), the vacuum gauge (GM#6460663), the backing plate that the oil pressure and vacuum gauge mount to, and I'm including a 60lb oil pressure gauge as well, as I've got no need for it (GM#6460746). The needles are still bright orange, the lens is only worn on the 6 spots where the foam rubber bumpers are, and everything appears to be in good working condition. I have never run it though.
**EDITED** I just checked the gauge, and it does work.**
Just install the lens, install the gauge and plumb it to your intake with 3/16" steel line. I've included the fitting on the back of the gauge, you'll need a brass ferrel (spelling??) and steel line from a parts store, that's it. YearOne sells this repro kit for $216....
$80 shipped
I've also got an extra lens that reads VACUUM. These lenses do not have tach numbering. $25 shipped for the extra lens
VTKidder is offline   Reply With Quote
Old 11-10-2003, 09:51 AM   #2
VTKidder
Lens.....if the picture isn't good enough, I can email a higher resolution pic for you, no disappointments on the lens though.
Old 11-10-2003, 09:53 AM   #3
VTKidder
Gauges.....
Old 11-11-2003, 02:38 AM   #4
FRANKIEPOTATAS
are you selling this only on ebay or are you going to pull it off of ebay if someone offers to buy it here?
FRANKIEPOTATAS is offline   Reply With Quote
Old 11-11-2003, 08:16 AM   #5
VTKidder
I put it on here for a day to give everyone here first dibs on it, but got a pile of looks, and no offers, so I put it on ebay before I went home last night. Unfortunately, since there are bids on it, I cannot pull it from ebay now. You'll have to bid on it that way. My apologies.....
-adam
