Old 02-25-2013, 12:07 AM   #1
stomper
Junior Member
stomper's Avatar
I cut one coil - lower than I expected - OK?
From what I learned on the board, I did this to get a 2" drop. The lower rubber bumper is barely touching the cross member. Front fenders and hood are not installed in this photo.
Can I just trim the bumper and be alright? ...or I have another set of springs I can try again.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 02-25-2013, 03:26 AM   #2
oldspowered67C10
Re: I cut one coil - lower than I expected - OK?
Just trim it.
oldspowered67C10 is offline   Reply With Quote
Old 02-25-2013, 08:10 AM   #3
midniteblues
midniteblues's Avatar
that looks pretty close you can trim the stop and try it out. hard turns and corners are where it might bottom out but you wont know till you try it
did you do anything with your shocks as they might hit before the bump stop
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-25-2013, 02:40 PM   #4
stomper
Junior Member
stomper's Avatar
I should add... The monroe sens-a-trac shocks have some travel left, the upper ball joint is not at it's limit yet, brake hoses have slack, and the springs stay in when I jack up the crossmember with the wheels off the ground. Hopefully it will align. Am I missing anything?
I don't recall the 2" drop springs in my other truck being this low. Maybe I ended up with 3"? I didn't measure it before because I'm changing so many things it's sort of a moot point.
Old 02-25-2013, 04:00 PM   #5
Xeen
Xeen's Avatar
A 2" drop in the front is as far as you can go with stock spindles before the alignment is unreconciable so you better hope it didnt lower it more than that, keep in mind if those are the original springs they could be worn out causing it to drop more than expected.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 02-25-2013, 05:34 PM   #6
LEEVON
Moderator
LEEVON's Avatar
That doesn't look too bad, the lower arms still appear relatively flat. Just trim the bumpstop and get it aligned and go from there. My truck is even lower and it aligned fine, just a couple extra shims up top.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-25-2013, 06:31 PM   #7
CC69Rat
CC69Rat's Avatar
Trim it or change to the flat round type bump stops maybe? I think youll be fine.
When one coil is cut you not only lose the length of the spring compared to stock but you also cut out that much spring tension. So.. it drops more than just the height of one unsprung coil.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-25-2013, 08:12 PM   #8
Square_78
Square_78's Avatar
You can probably just take the bump stops right out or cut them down. I wouldnt worry about the front shocks, they should be fine at that height and shouldnt bottom out.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 02-25-2013, 10:28 PM   #9
turp mcspray
turp mcspray's Avatar
I cut 2 coils out of a 67 I owned years ago. I had to remove the bump stop, and then remove the metal mount with a hacksaw, because it dropped WAY more than I expected. Someone had told me that they cut theirs 1 3/4 coils, so I figured I would go a tad more. He later said he was mistaken, and that he had cut 1 1/4 coils. Live and learn. LOL!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 02-25-2013, 10:42 PM   #10
CC69Rat
CC69Rat's Avatar
I have some stock coils, if you decide you need them they can be yours for the shipping costs. My zip is 37379, .. just whatever it takes to get them to you.
Chad
Old 02-26-2013, 07:55 AM   #11
DANTIP
DANTIP's Avatar
You could install air springs inside the coil and dial in your height. If I was going to drop the front with springs I'd try to do what you did knowing I can tune the height with the air springs.
DANTIP is offline   Reply With Quote
Old 02-26-2013, 08:05 AM   #12
Gumby
Gumby's Avatar
^ bags are very cheap too, its the built in compressors n fancy switchs that cost. drive it like a old school hotrod with airshocks, stop at a gas station for air when you need to raise it till you can spend $$$ on auto controls.
Gumby is offline   Reply With Quote
Old 02-26-2013, 08:44 AM   #13
CC69Rat
CC69Rat's Avatar
Its probably toe'd in just a little too now that the spring is shorter. Did you adjust the tie rod ends?
Chad
Old 02-27-2013, 07:59 PM   #14
stomper
Junior Member
stomper's Avatar
Thanks for all the replies. I'm going to trim the bump stop and go with it.
