Old 02-25-2013, 03:05 PM   #1
ljackson
ljackson's Avatar
Do the steering wheels interchange between 64, 5 & 6?
Do the steering wheels interchange between 64, 5 & 6? I thought they would. I installed a 66 deluxe steering wheel on my 64 Std. trim truck. There is no longer any space between the cup where the turn signal switch mounts, and the steering wheel. The 2 parts rub together. It seemed to go back together fine.
The steering wheel is from an automatic column. My truck has a 3 speed column. I’m not sure if this matters?
The arrow points to where parts rub.
BTW, the truck in the pic is not mine. I can't access my photos right now so I borrowed one.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 02-25-2013, 03:34 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Do the steering wheels interchange between 64, 5 & 6?
There's adjustment, there's a clasp at the cowl as well as below the dash to move it forward and back from the steering wheel.
Old 02-28-2013, 06:11 AM   #3
ljackson
ljackson's Avatar
Thanks aerotruk63, I thought the parts you mentioned just held the it in place. I did not know it would move to adjust. Is the part that you can move called the Mast Jacket as refered to in the assembly manual?
