Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-25-2013, 07:05 PM   #1
Sleeperc10
Radio not working right.
Hello everybody,
Im having troubles with my radio. I install an aftermarket stereo and everytime I turn my truck on it restarts the truck. Any help will be very appreciated.
Sleeperc10 is offline   Reply With Quote
Old 02-25-2013, 10:27 PM   #2
Sleeperc10
Re: Radio not working right.
I just read it and it doesnt restart the truck it restarts the radio, my bad haha.
Old 02-26-2013, 01:20 PM   #3
jimmydean
jimmydean's Avatar
Do you have both switched 12v and constant 12v connected? One turns the radio on when the key it on, the other saves your radio presets and clock.
If you don't have the 12v constant hooked up to a constant 12v source, your clock and radio presets will not stay set when the truck is turned off. Cig lighter is often a 12v constant.
If I am understanding the problem correctly.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-26-2013, 11:21 PM   #4
Sleeperc10
You are fully understanding what im trying to say, I will check my connections.
Old 02-27-2013, 03:15 AM   #5
jimmydean
jimmydean's Avatar
Depending on what year truck, you could tap a hot side of a fuse for a quick 12v constant, unless you know one to tap.
I have reverse my 12v connections before.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-27-2013, 07:28 PM   #6
Sleeperc10
I have a 72 short bed, Do you have any pics of the fuse box on your truck so I could see how you wired it?
Old 02-27-2013, 08:03 PM   #7
jimmydean
jimmydean's Avatar
Mine isn't wired to the fuse box, but it's an easy option if you need a source. Just use a test light with the key off and check each fuse to see what one has power with the key off. Then get a fuse tap from the local auto parts store and tap the hot side, or tap the wire. Depending on how clean you want to run it.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-27-2013, 11:35 PM   #8
Sleeperc10
Where is your wired too?
Old 02-28-2013, 01:42 PM   #9
jimmydean
jimmydean's Avatar
In my '92 it is wired off the factory radio harness, in my '66 I am using an all new harness with accessory connections for it (but my '66 doesn't use a traditional deck, it is running a tablet).
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 03-12-2013, 12:31 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
the voltage drop from starting the truck will cause the radio off and on again too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
