Old 11-10-2003, 05:08 PM   #1
cochino12
It followed me home?
cochino12's Avatar
welder
What kind of welders do you all own? I am gonna start building a blazer and want something I can use for body work and doing a c-notch. As you can probably tell I dont know much welding yet, I am trying to learn.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-10-2003, 05:18 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
I would look for a small MIG welder. It would be perfect for what you need. Miller makes small MIG welders that retail for $500-600 that are perfect for light usage....they weld like 1/4"-22 guage steel, and plug into a standard 115v outlet. MIG's are also dead simple to learn....almost like using a caulk gun, lol.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-10-2003, 05:29 PM   #3
crackajacka
Stylin
crackajacka's Avatar
yea there really easy to use, and it is like useing a caulk gun. i learned how to mig weld in like 6th grade lol
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 11-10-2003, 05:48 PM   #4
7T7
Regular guy
7T7's Avatar
I have a Hobart 175
We've done everything from full body shaves to stock floor body drops with it.
It’s s about 4 years old and have had zero problems.
Also look at the MILLERMATIC 175 it’s a little better made but also a little more $$.
7T7 is offline   Reply With Quote
Old 11-10-2003, 06:35 PM   #5
PHOENIX
I bought a Lincoln pro 135 ($420-430) 110v not long ago (Lowes).
I have welded up to 1/4" in a single pass with more then enough stregth. Have been using it a lot on different projects and I am happy with it so far. I took some welded steel parts out to the desert this weekend and shot it up. SKS would punch right through 1/4" mild steel plate no problem. When I shot the weld it still punched through, but the weld around the hole was still all there with no crack or sign of damage. Its a good little welder, thats easy to use and learn.
I was concerned about it at first, but have used it on the same circuit as other things like an air compressor and havent even popped a breaker yet. No complaints so far (used it on sheet metal and 1/4"). Havent used it for aluminum yet.
A welder I could plug in anywhere was a must, thats why I bought the 135 (110v). Something important to consider.
If you plan to use it in one spot all the time, spend a extra $100 and get a 175 (220v). If you want to use gas all you need to buy is the tank, everything else is included.
LINK:
http://67-72chevytrucks.com/vboard/s...threadid=74272
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 11-11-2003, 12:30 AM   #6
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Holy crap! Reading this made me realized that I forgot to turn on my new auto darking helmet tonight while I was using it. Hope my eyes wont be burning to bad in the morning. I feel like and idiot! CRAP, CRAP, CRAP!! P.S. don't forget to turn on the helmet.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 11-11-2003, 12:57 AM   #7
Russell
Professional Grade
Russell's Avatar
Wouldn't you notice that it was awfully bright while you were welding? lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-11-2003, 01:03 AM   #8
toytruck
toytruck's Avatar
No its still dark. Its gets lighter when you turn them on and when you strike and arc it goes darker.
Old 11-11-2003, 01:04 AM   #9
Mike76251
Here is mine,
It is a 285 amp 24hp gas machine.
Mike76251 is offline   Reply With Quote
Old 11-11-2003, 01:06 AM   #10
lukecp
lukecp's Avatar
A guy i knew back in high school got the "bright" (pun intended...hehe) idea to weld in cutting torch goggles during shop class. He burned his eyes pretty bad and had to leave school and go to the doctor
Old 11-11-2003, 01:58 AM   #11
Mike76251
Go to the doctor with burned eyes?
There's nothing that will cure that! LOL
That is really too bad though as it does permanent damage to the eyes when you throw that much UV at them.
