Old 02-25-2013, 10:12 PM   #1
Project77
drivers side window issues
okay fellas heres what i got my drivers side window has always had this problem with stripping out the old plastic door handles that came with it from the factory so i bought a pair of vice grips and used them ever since
i could make a full 3/4 rotation then it would get really stiff and not want to roll up for **** unless i jiggled it a little bit. but lately its been so hard and ive been so impatient i stripped out my shaft where the handle slides onto.
also the window wont sit like its supposed to it seems to want to slide back on the track like it has no back brace but you can take the window and slide it forward and back but you cant do that with the passenger window(it works properly and has no issues)
i have another truck that i use for parts and it has the same setup and works properly and i want to know if anyone has step by step instructions on swaping the whole window unit set up i have pics of my issues...
Project77 is offline   Reply With Quote
Old 02-26-2013, 11:13 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: drivers side window issues
it shouldnt come out like that
take off the door panel,i'm sure it will be something hanging
compared to your other one
4 bolts, twisting and turning ,in and out
the later style "metal" ones fit too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-26-2013, 11:27 AM   #3
blazer2007
I just did mine ,was a piece of cake,look on u tube was a good one ,I think I typed in replaceing window channel
blazer2007 is offline   Reply With Quote
Old 02-26-2013, 11:40 AM   #4
Project77
Thank y'all I think there is a bracket inside that is broke
Old 02-26-2013, 11:44 AM   #5
Low87
been here longer than Liz
Low87's Avatar
I was going to mention the wondow channel also. Sometimes it slides down and binds up inside the door. Should be an easy fix for you if this is the case.
Also check the assembly shown above. Could be dry and in need of a greasing.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 02-26-2013, 12:02 PM   #6
silvereagle07
silvereagle07's Avatar
You need to check the window run too. If its not torn you need to clean out the old debri with a nylon brush and lube the run too. Also lube the window slide track and rollers for smoother operation.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-28-2013, 09:02 PM   #7
Project77
well i figured out what my problem here is! the channel right next to the door handle is broken off i pulled it right out the holes look like they have been ****ed up so im going to wait till the summer when im getting her ready for paint i have a parts truck with two doors in perfect condition i will just use them.
