Can someone set me straight 305 to 350
I am going to buy a basic 350 crate maybe a 260hp to replace the original 305 in my 86 silverado shortbox.
I don't ever plan to add any performance mods to the motor I just want a reliable motor for my everyday driver with low end torque and similar economy to the 305. What I need to know is will the exhaust manifolds,ignition,quadrajet and inlet manifold.water pump ,fuel pump all swap over ? I am getting a shop to do the change over here in Australia and when getting quotes they all say different things concerning the the above. Way too lazy to do the change over myself. |
Re: Can someone set me straight 305 to 350
Yepp, it will all bolt right up
80 K10 350 4 spd 4 Inch lift, 33 inch BFG M/t |
everything will swap, and economy should be comperable
oi mate, who's doin your swap over?
I'm in hallam. truck pics? |
#6 | |
Pm me your number and I will give you a call. |
hold on a second. you said your new 350 will have a two piece main. if thats true. then your intake probably wont work, and neither will your valve covers.
the 2 piece main engines are older 85 and older and the one piece is 86 and up. I would not go to a 2 piece rear main unless I had two. Point is make sure your getting the the same generation engine your swaping to make sure all the stuff switches over |
Yes the flex plates are diff from one piece and two piece rear seal, new flex is about $125 or so but before ordering count the teeth on old one. I wouldnt reuse old water pump or distributer though
Can you post a link to the exact engine your thinking if getting? Posted via Mobile Device
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
http://www.cmp.com.au/crate-engines/...te-engine.html
From what I can understand from reading here and elsewhere The LE9 in my 86 is sort of an odd ball year with one piece rear seal but a mechanical fuel pump. Have looked into getting one shipped from the US but works out the same with shipping. They also have this motor http://www.cmp.com.au/crate-engines/...ylinder-h.html but then I need a electric fuel pump inlet manifold . Maybe I would be better buying a turn key motor from the US and get it shipped by the company that shipped the truck.That would take 6 weeks to get here. Would be in no hurry but the 305 is very tired and wants to quit pretty soon. As I said economy is more important than horse power for me but I suppose if I keep my foot out of the throttle there is no harm in having it? |
yes your engine in your 86 was right in the middle of the transition to newer engine and fuel injection. all of the newer engine should have the provision for mechanical fuel pump. your intake will not fit the vortex heads on the 330hp engine. you should have no problem with the other engines. Why dont you have your engine rebuilt. I would think it would be cheaper anyway?
Why not just have your 305 rebuilt? That new block gonna have made in Mexico cast on back
This is Australia!The most expensive country in the world for everything. To rebuild my 305 here would cost more than a new crate motor and I would prefer the extra torque of a 350.
#13 | |
There is no replacement for displacement.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
#14 | |
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
#15 | |
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab ![]() |
#16 |
I just don't like the made in Mexico cheap blocks
#17 |
That's quite a change of post from the one you deleted......
#18 | |
We actually use them in boats as it eliminates the leak issues in the rear main but the older intake and fuel pump work PN 12568759 $1600.00 in Canada |
#19 |
ya....forgot what website forum I was on
#20 | |
ph: 9796 5275 7am-3pm mon-fri ask for chris |
#21 |
when people buy those cheap crate mexican engines locally, most people get them rebuilt no one stands by them, not even those who sell them.
why not get a smashed up vt-vx grab the ls1 outta there, i seen rear end wrecked cars go for 2K with ls1 and 150K on the dial. that would be a mental swap and you have everything you need from the donor car. by the same token aussie 5 litre 304 v8 outta vt low comp for forced induction lots of choices |
#22 | |
#23 | |
#24 |
hahaha fair call ozkiwi
my missus is a maori |
#25 |
I'm sure I will catch some grief for this but what the hell here goes. I'm not sure where and why 305s have gotten such a bad wrap, they are great little engines and can be made to perform very well, some one wanting to go from a 305 to a 350 for the extra torque is absurd. Both engines share the same crank they will interchange as will the rods, torque is based on stroke and the only way to increase torque is to increase stroke this is why the 383 is so popular. I would never swap just to have a 350, my truck currently has a 334 in it, (A 400 crank in the 305 block.) the small bore allows for some impressive mileage figures, while having the ability to out run most 355s.
I just had to get that out, it is all in what you want to do and the funds allowed, I have a little over 400 dollars in this engine and it has done well by me, thought I would stand up for the 305.
Rally 'round the family....with a pocket full of shells. |
