The Older Generation
Manual Fuel Transfer Valves
These are 2 way (2 in 1 out) manual fuel transfer valves. They look to be in good shape and levers are tight. They turn easily but snug. The first one (pictures in first post) has 3/8" hose barb fittings on all 3 connections and the label plate(First one is SOLD). The second one (pictures in second post) has compression fitting connections and no label plate. There are 2 mounting bolt holes on each as you can see in the pictures. Your choice, $25 shipped. Per board rules post in thread before any PM's. PayPal or Money Order works for me.... LockDoc Valve #1
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-03-2013 at 01:44 PM. |
Re: Manual Fuel Transfer Valves
Valve #2
![]() Join Date: Jul 2011
I'll take the first one with the plate.....pm me your paypal info.......thanks.....dwt.
Posted via Mobile Device |
#4 | |
PM sent with payment info. Thanks. LockDoc
Paypal sent......thanks.......dwt.
I still have the 2nd valve for sale. Thanks LockDoc
Carpe manana
![]() ![]() Join Date: Dec 2010
Leon - I'm interested in the remaining valve but do you know which fitting represents the output? Trying to ensure the settings will jive with the "left" and "main" positions on the floor mounted bezel plate for the 72 aux tank option. Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#8 | |
Pete, See the picture below. LockDoc
Carpe manana
Thanks Leon - on the floor bezel the left and main tank positions are at 90 degrees to each other. Looks like this valve has them 180 degrees apart so will pass. Appreciate the help. Pete
#10 | |
The positions on this valve are 90º between the two tank positions. One tank is the position you see in the picture. For the other position the pointer (short end of the lever) is pointed toward the outlet fitting. LockDoc
Carpe manana
PM sent Leon...if that's case I'll take it. Thanks for clarifying - Pete
