Old 02-27-2013, 09:20 AM   #1
ZUBZ
ZUBZ's Avatar
Correct oil for 307 v8 ?
Hi all,
What would be the correct viscosity of oil I need to use on a 70 c10, 307 v8.
Has like 100k miles plus.....
I have been told 20W50 is correct.
ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa
My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560
ZUBZ is offline   Reply With Quote
Old 02-27-2013, 11:22 AM   #2
msgdsrf
Re: Correct oil for 307 v8 ?
Depends on use. I would never use 20W-50 because of the amount of additive needed for such a broad range which break down quicker (less protection and sludge buildup). Also consider what your oil preassure is, 50 weight is pretty high for for SBC (unless your preassure is low).
Winter temps cold in J Burg that you want a Winter (W) oil? 10W-30 is commonly used, 30 is what was used, can you get 20W-40?
msgdsrf is offline   Reply With Quote
Old 02-27-2013, 12:24 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I once switched from 10W-30 to 20W-50 in a tired 350 sbc. No problems and it used less oil between changes. But unless your engine is pretty well worn out, 10W-30 will work just fine and should be readily available.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-27-2013, 03:12 PM   #4
ZUBZ
ZUBZ's Avatar
Thanks, yeah the winters to tend to get cold. I will check on 20W-40 but I am sure it is available
Old 02-27-2013, 03:23 PM   #5
ZUBZ
ZUBZ's Avatar
Thanks Stocker, let me see what is available first locally and then decide.
