Old 02-28-2013, 03:02 AM   #1
Chev86c10
axle
I just bought a 1986 c10 chevy shortbed and I thinking about changing the drum brakes into rotors and and disc brakes is it worth to switch???
Chev86c10 is offline   Reply With Quote
Old 02-28-2013, 04:27 AM   #2
stroker52
Re: axle
yes but you have to change a few other things. you cant just throw on a set of rear disks an call it a day. the master cyl. needs to be changed to a disk/disk set up plus change the proportioning valve
stroker52 is offline   Reply With Quote
Old 02-28-2013, 07:46 AM   #3
Keith Seymore
Keith Seymore's Avatar
Re: axle
Worth it in what way?
Performance wise (daily driver): the production rear drums are sufficient. Most of the braking is done with the front on any vehicle, but in particular a pickup truck because of the minimal weight on the rear.
Performance wise (race truck): maybe, but still limited by the above weight distribution and dynamic realities
Visual impact: maybe - disc might be arguably more "attractive".
Only you can decide on your truck. My trucks all retain the drums on the rear.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-28-2013, 09:40 AM   #4
GM-power
GM-power's Avatar
Re: axle
I agree with Keith. If it ain't broke dont fix it. I have not had a problem stopping with a these trucks. I would spend the dough for something you could use.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 02-28-2013, 10:03 AM   #5
andrewmp6
Re: axle
I'd leave it drums they last a lot longer then disc and cheaper to rebuild vs rear disc and pads will be.
Old 02-28-2013, 12:51 PM   #6
Chev86c10
Re: axle
thanks guys i was going to rebuild the whole rear break system. now with this information i will just put on brand new drum brakes and call it a day
Old 02-28-2013, 12:55 PM   #7
dieseldawg142
dieseldawg142's Avatar
Re: axle
also converting to disc can be a pain fabbing up an e-brake that actually works
dieseldawg142 is offline   Reply With Quote
