Old 02-28-2013, 06:38 PM   #1
see ten
WTB this ad
see ten's Avatar
Simple fuel filler
I've seen a couple threads with people asking about fuel fillers and wanting suggestions of how to build one for cheap. Here's what we built...
That's one piece of sheetmetal with 2 bends and 1 weld forming the outer "box". Welded a piece of small angle to the part of the box where it contacts the stake pocket and the bedside... drilled and tapped the bed for 1/4" bolts. The access panel allowed us to reach in to attach it to the bed as well as hook up the filler hose, vent and cap. Used a 90 degree piece of exhaust tubing to make the curve to the fuel cell, rubber fuel line goes from the 90 to the fuel cell, and to the cap. Box was sprayed with bedliner material before it was installed.
see ten is offline   Reply With Quote
Old 02-28-2013, 06:48 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Simple fuel filler
First one we did like this... same concept just uses a "pop up" style cap. The angle of the cap dictated the angle of the top of the box. Has been in use over 2 years. Rattle can paint job on a truck that's been worked like a chinese slave...
View from under the bed...
Old 02-28-2013, 06:49 PM   #3
72 K20
72 K20's Avatar
That's sharp !! Very nice work !!
72 K20 is offline   Reply With Quote
Old 02-28-2013, 06:51 PM   #4
vidman
vidman's Avatar
That is one sweet looking gas filler...Very very cool
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 03-10-2013, 07:38 PM   #5
RaceAGMC
RaceAGMC's Avatar
Something like that would be neat with an old Jerry can.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 03-10-2013, 10:34 PM   #6
Husker
Husker's Avatar
Where did you get the cap?
Nice job.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-11-2013, 06:38 AM   #7
see ten
WTB this ad
see ten's Avatar
Both caps came from ebay and were listed as "boat" fuel fillers. The pop up cap worked great until it got moisture in it combined with below freezing temperatures... caused it to fail to "pop up". Plans are to replace it with another one just like it and see what happens. The flip top cap seems to work well so far... the opening is actually larger.
