#176 |
Knuckle head
Re: Project Step Aside, 1971 SWB/Step
I know it has been a while since I have posted but rest assured because they have arrived.
Adam '71 SWB/Step ![]() 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. ![]() |
#177 |
Knuckle head
This is the "finished" floor pan and firewall.
#178 |
Knuckle head
Here are the new seats I got. Corbeau A4
#179 |
Man of Mini-Talents
That's looking killer! All you lack is finishing up.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#180 |
Knuckle head
Here are a few more pics. I am still in the mock up phase and now trying to figure out a good way to mount the bed and still use the wooden bed. Right now I built a frame work out of 3/4" square tubing and I plan on using some rubber isolater material between it and the frame rails. I got the rear-end completed and welded up, third member installed, and Moser axles installed. I ordered Mar-K bedsides and front bed panel and they are some of the nicest replacement panels money can buy. I am also starting to mock up the radiator and other front end parts.
#181 |
Working progress !!! Love it
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
#182 |
Knuckle head
If anyone is thinking about getting the 80 Gallon single stage Kobalt air compressor from Lowe's, my advice is get a different one. I bought one a little over a month ago and followed all the lube guidelines, compressor gets hot leaks oil and now seizes up and can't get to 150 psi without blowing a 220v 30a breaker.
I love my local Lowe's and their customer service here, they are coming today with a new one and taking the old one back. The simple fact remains though, I should have done my homework and looked at the reviews of it. That's what I get for trying to save money by using my 10% military discount.
#183 |
![]() Join Date: Dec 2006
Truck is looking great, can't wait to see it back on the ground. Sorry to hear about your compressor issues, hopefully Lowes resolves them for you.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#184 |
![]() Join Date: Aug 2012
I bought the same compresser from Lowes. I used it about 6 months now. I had only one thing that went wrong with it. The main pulley on the compresser kept coming loose. I tighten it and now it is doing great. I have sand blasted and grind and used a DA sander and it keeps up with me. I am sorry for you trouble. But sometimes a bad one or a good one gets by. But it does get a little warm sometimes. So I mounted a fan over the compresser when I willl used it for a while. Signed some what happy with it.
#185 |
67cheby
![]() Join Date: Sep 2008
great progress, frame looks great, that radiator is pretty sweet too !
#186 | ||
Knuckle head
Thanks man, hopefully I can get those slosh tubs put in soon.
#187 |
Knuckle head
To the few who have been following this, I apologize for the lack of replies. I had to leave town for a few month for work and got home around Halloween. I hit a deer in my '09 right after lifting it an throwing new rims/tires on it. Had to get it fixed and it looks great now just spending time tuning it.
I also took a huge step and proposed to my girlfriend last night and the crazy girl said yes. WOOO HOOO!!! (There goes the money for the motor... Doh)
#188 |
motor exploder
Congrats on the engagement! That '09 looks sweet as does what you've done to your '71. Can't wait to see the 'Step Aside' finished - great work so far!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#189 |
Glad to see your back at it and congrats on the engagement. Can't wait to see more updates on your step side. Oh and your 09 looks pretty sweet too.
#190 |
did you fab that frame bracing or is it a kit? I saw a couple pages back you put in some supports and then on this page you magically have a full frame brace. details man!!! looks awesome.
#191 | ||
Knuckle head
Yeah I built it. The only stuff I didn't build was the 4-link and the touring dropmember and A-arms. I made a template I thought would look good and bent it up at work.
#192 |
Knuckle head
I realized that I never posted photos of the cab after I epoxy primed it prior to my deployment. I also started to smooth out the cowl.... wish me luck.
#193 |
You're going to have a killer truck when you're finished. Subscribed
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
#194 |
Still Learning
Love your truck! you have made some killer progress since starting. This thing is going to so nice. I feel your pain with all the rust repair and body work. Subscribed....
#195 |
Knuckle head
Got a little done over the last couple days. Finished smoothing the cowl and TIG welded some brackets with nutzerts in them to the radiator to mount it a little cleaner than I had it before. I am happier with the way it looks I just wish my TIG skills weren't so rusty. I also replaced the PS lower lip with a hand made one and modified the radiator opening a bit.
#196 |
Knuckle head
#197 |
Nice job on the cowl, looks great
#198 |
Looking killer man, whats next on the to-do list?
#199 |
Knuckle head
The to do list is a mile long and I seem to jump around from one part to another. I was at a stand still on the rest of the frame until I figured out how I was going to mount my roll cage to the frame. I need it to warm up so I can epoxy prime some more blasted parts and the frame but it has been too cold to get it done. I am going to paint my frame rather than powder coat since it is going to be a continuing project. I am nearly certain I am going to change a couple things prior to final assembly and removing and reapplying paint is a heck of a lot easier than powder coat. I may make the solid body mounts I need and get the cab mounted and start installing the cage.
#200 | |
