03-02-2013, 03:23 PM | #1 |
Cluster wiring
This might should go in the electrical section however it is specific to these trucks so figured I would ask here. I have a 67 pickup that had a no guage cluster. I have since added gauges to this and now it is time to wire.
The new temp and oil gauges are electric, my question is can I use the factory wires that used to go to the dummy lights as the wires that now would be sending the signal? Ie can i take the wire from the old sensor, hook it to the new sensor then under the dash run that wire to the new gauge. It may be a smiple question, just did not not know if the wires were of a resistance type like the coil wire where you have to change it out to power hei ignitions. Thanks in advance. |
03-02-2013, 05:21 PM | #2 |
Re: Cluster wiring
Yes you can use those wires with the corresponding sending units. but the factory oil gauge used a tube. If you are useing an after market gas gauge you will need a matching sending unit, although some use the factory sender.
03-02-2013, 06:00 PM | #3 |
Re: Cluster wiring
Oil gauge uses a tube but the dummy light uses a wire. Same with temp. Those are the wires I want to use on aftermarket gauges. Fuel gauge is still stock.
Posted via Mobile Device |
