Old 03-02-2013, 11:05 PM   #1
G8DAN
G8DAN's Avatar
Quick Ratio Steering Box
Hey guys, I was doing some research and could not find a definite answer.
Will this agr box fit all C10s from 73-87? I remember reading something on how some boxes will only fit 80+. I have a 77 1/2 ton and am looking to upgrade the box soon.
http://www.summitracing.com/parts/AGR-244451/
If this one does not fit, does anyone have any recomendation on a box that would fit my application?
Thank you in advance.
G8DAN is offline   Reply With Quote
Old 03-03-2013, 10:36 AM   #2
bdiamond
Re: Quick Ratio Steering Box
The fittings may be different. Not sure when they switched to metric fittings.
Taken from a car craft writeup: In the '80 model year, GM also changed from its original 45-degree inverted flare 5/8x18 UF and 11/16x18 UNS female fitting sizes to a metric O-ring (often called Saginaw fittings) measuring 16x1.5 mm and 18x1.5 mm
Read more: http://www.carcraft.com/techarticles...#ixzz2MUHqD3fN
bdiamond is offline   Reply With Quote
Old 03-03-2013, 11:23 AM   #3
80SPORT
80SPORT's Avatar
That is correct
73-79 fit
80-87/91
2wd and 4wd are different
80SPORT is offline   Reply With Quote
Old 03-03-2013, 07:43 PM   #4
Ziegelsteinfaust
Do they have a quick ratio early box?
Or do we have to change completely over to later model stuff?
Ziegelsteinfaust is offline   Reply With Quote
Old 03-04-2013, 02:48 PM   #5
G8DAN
G8DAN's Avatar
Thanks guys for the feedback. Looks like my only option is to have one built for me. Right?
Old 03-04-2013, 09:07 PM   #6
bdiamond
AGR can build one. You can spec ratio and torsion bar diameter. Call them and talk with their tech guy.
