03-03-2013, 06:25 AM | #1 |
oil pan hitting crossmember
after installing a 509 big block in my 72 c10 2wd i noticed the oil pan just about hitting the front crossmember.i have seen guys notching the crossmember but has anybody shimmed the motor mounts? i just need a quarter inch.i gave up trying to find a different oil pan.thanks
03-03-2013, 10:25 AM | #2 |
Re: oil pan hitting crossmember
What pan are you using???
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
03-03-2013, 10:32 AM | #3 | ||
"I ain't nobody, dork."
Are the motor mounts for a BBC? Are the stands in the correct location?
Gary
03-03-2013, 11:23 AM | #4 |
my truck is a old drag racing truck it had a 468 cu in motor that was blown up.the oil pan rubbed a little bit with that motor in it.i think it has the original chevy oil pan.not sure on the mounts, good question i will have to find photos of small block and big block mounts/stands and compare.the mounts look factory.thanks for the help i will try to post photos.
03-03-2013, 11:31 AM | #5 |
if it is only a quarter inch or so?? me i would take the torch get the bad area of crossmember cherry red and a nice large hammer and clearance the thing with a nice even relief/// oldschool modification been done like that for as long as i can remember
03-03-2013, 11:58 AM | #6 | ||
Nothin' like a torch and a BFH...
Gary
03-03-2013, 05:49 PM | #7 |
thanks cdowns i will try and find a photo on a build thread of how close the pan is on other members trucks.
03-07-2013, 07:48 PM | #8 |
thanks GASoline 71 your right the po installed the big block on small block mounts,i did not notice till i saw a thread on the subject and saw the motor sitting up higher than mine.
