Old 03-03-2013, 09:53 PM   #1
Yellow72C10
Power steering help?
How can I bleed the power steering on my truck? 72 k10 with a350, if that helps. Thanks!!!!
Yellow72C10 is offline   Reply With Quote
Old 03-03-2013, 10:20 PM   #2
brans72
Re: Power steering help?
I fill them up little over the correct level and leave cap off, then crank it turning wheel lock to lock couple times,then cut off and check fluid,repeat till all ir is out and steering feels good. takes normally 10-15 mins.
brans72 is offline   Reply With Quote
Old 03-03-2013, 10:20 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Power steering help?
One hose is the low pressure side it's held on with clamps take it loose and let it run into a jug. Are take the fitting loose on back of pump housing loose and let it drain into jug.
Got to Harbor frieght and buy a cheap hand pump for like $4.00 and pump it out.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-03-2013, 10:23 PM   #4
asolde
asolde's Avatar
That's what I did.
asolde is offline   Reply With Quote
Old 03-03-2013, 10:29 PM   #5
brans72
Should be good check for any air bubbles in fluid container and you should be good to go if there gone.
Old 03-03-2013, 10:31 PM   #6
Yellow72C10
Where is container that holds fluid? Sorry I'm a newbie
Old 03-03-2013, 11:32 PM   #7
Andy4639
Old member
Andy4639's Avatar
You want to just get air out of the system then and not bleed the system. Correct?
The pump is the one with nut on the shaft. Silver lid take it off and fill it up. Jack the truck up and turn the steering to lock in both directions a few times. Then crank the truck and do it a few more times.
Old 03-04-2013, 04:40 PM   #8
Yellow72C10
Thanks!
Old 03-04-2013, 04:52 PM   #9
SS Tim
SS Tim's Avatar
If you don't have the service and overhaul manuals you really need to download them.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
