Closed Thread
Old 03-02-2013, 09:15 PM   #6201
Trsmotrhed
Trsmotrhed's Avatar
Re: What did you do to your truck today!
Originally Posted by Jarwood View Post
Carpet in and seats mounted.
Really like the look of the seats with the leather? I have the same seat in cloth and would really like to do what you did. Was that a kit or you have someone recover them. Thx
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 03-02-2013, 10:21 PM   #6202
Z10
Z10's Avatar
Put my serpentine system and valve covers on the new ZZ4.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 03-02-2013, 10:29 PM   #6203
buckskins4ever
buckskins4ever's Avatar
Originally Posted by THE BOSS View Post
i use photobucket.com
a free site, upload there, copy paste to here.
first upload at photobucket
with 2 tabs opened, on there one there
find IMG code near the picture you uploaded, click on IMG code and it automatically copies, tab back to here and paste where put your messages/comments.
click enter after paste if you do more than 1 picture, the pasted code must on it's own line. hit enter twice, three times to put space between the pictures if you want.
you can also click on preview here to see what it will look like before you submit it.
Thanks, I finally gor it figured out with help from another member. gonna get a few pics uploaded soon.
buckskins4ever is offline
Old 03-02-2013, 10:46 PM   #6204
buckskins4ever
got the interior seats and door panels about two months ago, they are Grey Ultra Leather, with black Ostrich and Orange Vinyl inserts.
Shortly there after put in the Flame River Polished Aluminum Titl Steering and Grant Signature Series Steering wheel.
got the Dakota Digital HFX Dash installed on Friday afternoon just in time to go down to install the Ridler 695 Chrome rims.
Old 03-02-2013, 10:58 PM   #6205
eldogg
eldogg's Avatar
I finished building the front clip for my brother's 65 GMC. OOO yeah I had to build a new tool too. Anybody guess what it is/does?
eldogg is offline
Old 03-03-2013, 02:15 AM   #6206
Jarwood
Jarwood's Avatar
Thanks!
They were cloth out of a 2003 truck. I had them covered with a local upholstery shop. They are not real leather...but only cost me $300. Thats with any color combination or type. I picked the preforated red in center.
Jarwood is offline
Old 03-03-2013, 02:33 AM   #6207
Trsmotrhed
Trsmotrhed's Avatar
Thanks!
Thanks for the info. Really like the look.
63 SWB C10
Old 03-03-2013, 02:38 AM   #6208
thelonerife
thelonerife's Avatar
started smoothing my fenders. I'm going with porter built hinges. Not done.
thelonerife is offline
Old 03-03-2013, 07:00 PM   #6209
jjhare
jjhare's Avatar
Helped my son paint the engine!! and we got some more of the 40 year old crud scraped off other parts!
1972 C10 CST LWB
jjhare is offline
Old 03-03-2013, 07:10 PM   #6210
mightymouse
mightymouse's Avatar
is it to help press the bushings
mightymouse is offline
Old 03-03-2013, 07:59 PM   #6211
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
After playing around in the Ign Unfused portion of the fuse box to hook up a direct like to the HEI yesterday or the day before, I was sure
I had dislodged the cluster feed wire, since my headlight adjustment test last night had me in the dark....as far as the dash lights go, at least.
Looked under there today.....with a flashlight. Everything was hooked up as I had left it. The 3A Cluster Feed fuse looked good.
But I had slept on the issue last night and couldn't figure out what else could have been the problem. So, I pulled the fuse and gave
it a good look in the sun. Looked good. My eyes are pretty good. I trust them.
But those squiggly-lined 3A fuses are tricky. So I decided to put the continuity tester on it. Bad fuse. Not bad anywhere I could tell
even after taking it over to the bench and shining a light on it with different backgrounds behind the glass tube. Still...Bad tube.
New fuse in. Dash lights on.
Just a tip for anyone else who trusts his eyes more than his brain....Like me.
Here's two "starts" (used two different cabs), and the "stop" (for now).
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-04-2013, 02:17 AM   #6212
ksucatz
Suppose to be workin........
ksucatz's Avatar
Well, not really today, but thought I would share.
What started out as a a simple replacing the temperature gauge turned into a refurbishing of the gauge cluster. I took everything apart, cleaned the bezel, blasted and repainted, and painted all the needles. I then decided to go a little further and converted the ammeter to a voltage gauge. Happened to find a voltmeter from a early 80's era truck in the boneyard. The actual mechanicals are identical to the early trucks, so all it took was swapping the face from my old ammeter to the new gauge, and install the original needle. It is set so when in the middle it indicates 13 VDC. I think this will be much more useful for indication.
If I was a little more ambitious, I might of had a new overlay made for the gauge, but will be happy with this.
Oh and the gauge was a freebie, total cost including the new temp gauge and paint, is about $49. Not too bad for a couple evening's work.
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
"Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown
ksucatz is offline
Old 03-04-2013, 02:40 AM   #6213
PAWS 72
PAWS 72's Avatar
Went to mom and dad's. Got to going through some of my grandparents papers that mother had questions about I found a bunch of interesting old stuff my Granddad brought back from the service with him.He never did talk about the Army but about him and his twin brother's escapades they had.
I posted some pics in the cool old car section. But look here.....Guys I miss him
PAWS 72 is offline
Old 03-04-2013, 08:31 AM   #6214
eldogg
eldogg's Avatar
Yeah. I'm all the time using sockets to press things and got tired of having my hand in the line of fire. Safety First Kids! lol.
eldogg is offline
Old 03-04-2013, 09:24 AM   #6215
midniteblues
midniteblues's Avatar
I must be makeing some kinda progress 2 posts on the same page
I'm stoked i picked up this original paint rust free 67 step fender from cl last nite.it has a flange! a complete rust free flange!
it has a few small dings nothing that couldnt be tapped out
I wont need too weld on this one
parts like this are unheard of here in pa
the fell'a i got it from said he was a board member but hasnt been on in a while and couldnt remember his board name.
its just cool too meet other truck guys in the area
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 03-04-2013, 11:34 AM   #6216
mmmBoost
Got my plastic glove box via eBay
I installed my upper shock mount conversion
Installed CPP Crossmember
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 03-04-2013, 02:31 PM   #6217
~Whitey~
~Whitey~'s Avatar
I undercoated my cab, not today, but yesterday. :-)
I used Herculiner, brushed the first coat, sprayed the second coat, then followed up with Herculiner UV protection.
Jimmy
.69SWB Build.
~Whitey~ is offline
Old 03-04-2013, 04:48 PM   #6218
magwakeenercew2jh
Decided to turn the cheapo center-console into a radio room.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-04-2013, 05:04 PM   #6219
1972SUPERSB
1972SUPERSB's Avatar
Let us know how the plastic glove box looks and fits with pics!
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline
Old 03-04-2013, 06:41 PM   #6220
Square_78
Square_78's Avatar
new 15x8 wheels on today... took the trim rings off my 78 for now. Baby moons on order and should be in tomorrow. I already like how it looks!
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline
Old 03-04-2013, 06:45 PM   #6221
ole dollor
ole dollor's Avatar
thats going to look good...i like baby moons
ole dollor is offline
Old 03-04-2013, 07:46 PM   #6222
rogergodding
rogergodding's Avatar
Took the bed off mine, getting ready for a Camaro fuel tank install....
rogergodding is offline
Old 03-04-2013, 09:16 PM   #6223
myyamr7
myyamr7's Avatar
Painted my engine, put on the new motor mounts and some new heat shields for the plug wires. Waiting for the stainless exhaust manifold bolts to come in, and still have to clean and paint an older set of stock valve covers
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline
Old 03-04-2013, 09:22 PM   #6224
buckskins4ever
I got mine out and drove it all day......YES!!!! Then I ordered a Boyd Aluminum Tank and priced out my A/C
Old 03-04-2013, 09:45 PM   #6225
Jarwood
Jarwood's Avatar
Buckskins4ever, Everytime I look at your truck, I think man its beautiful!
Jarwood is offline
Closed Thread
