03-04-2013, 05:50 PM | #1 |
peel and stick
Where do you guys/gals get your sound deadener from and what do you get? I went to home depot and lowes and they didn't have any. Also how much do i need? Thanks
Posted via Mobile Device |
03-04-2013, 06:28 PM | #2 |
Re: peel and stick
MusicMan70 1961 GMC Suburban |
03-04-2013, 06:29 PM | #3 |
Re: peel and stick
There a few different makes out there of peel and stick sound deadener. You will have to go to or through a Car audio place to purchase or order online. Dynamat is one of the originals. If you are ok with using a 3M industrial spray adhesive you can go to lowes and they are carrying a new double sided aluminum insulator and deadener by the roll and you can get it in 18", 24", and 36" wide rolls.
03-04-2013, 07:01 PM | #4 |
Re: peel and stick
Did you look in the hvac section and it's also in the window / door section @ HD
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
03-04-2013, 07:28 PM | #5 |
Re: peel and stick
03-04-2013, 07:29 PM | #6 | |
Re: peel and stick
03-04-2013, 07:36 PM | #7 |
Re: peel and stick
I actually have it inside my doors, on my cab walls, and completely lined the underside of my hood with it. Just remember if you use it, spray both the insulator and metal with glue before sticking. My floor is completely covered with Dynomat.
03-04-2013, 10:55 PM | #8 |
Re: peel and stick
Raammat is very good and cheaper than Dynamat. Whatever you end up buying, take some time to read the information on www.sounddeadenershowdown.com. In brief, you only need to use the metal/butyl stuff on 25-50% of the sheet metal. Anything more than that is a waste, as this material primarily serves to dampen vibration.
For sound deadening, you should put a layer of foam (I used Ensolite) on top of the mat, then finish it off with mass-loaded vinyl (a material used in construction, it is very heavy and therefore not for mail-order, you can find it at local insulation supply houses). The MLV is what really stops sound from transmitting through your cab. Sound Deadener Showdown explains all this very well (he also sells material). Here are links to my sound deadening project: Raammat: https://picasaweb.google.com/lh/phot...eat=directlink Ensolite Foam: https://picasaweb.google.com/lh/phot...eat=directlink Mass Loaded Vinyl: https://picasaweb.google.com/lh/phot...eat=directlink Good luck! |
03-05-2013, 01:14 AM | #9 |
Re: peel and stick
I used fatmat. They come in a kit with roller and 50sq ft for $79.99. Worked great and covered floor, kick panels, and behind gas tank.
03-05-2013, 01:49 AM | #10 |
Re: peel and stick
you can use weatherguard that can come from home depot
03-05-2013, 08:30 PM | #11 |
Re: peel and stick
03-05-2013, 10:02 PM | #12 |
Re: peel and stick
Yeah I put carpet over it.
03-05-2013, 10:17 PM | #13 |
Re: peel and stick
I've used FatMat a lot for recent audio installs. Its good stuff and works very well. I can usually find a good deal on it on Ebay.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
