Old 03-04-2013, 06:52 PM   #1
cmax87v3500
cmax87v3500's Avatar
tbi intake question
so i have a 1987 gmc v3500 with a tbi 454. it came stock with the carb intake with the gm spacer to make the tbi fit. this spacer has coolant running through it. i just got the edelbrock performer tbi intake for it, and it has the same provisions for the coolant to run into the intake just below the tbi. my question is, what is the purpose to have coolant running through the intake in this area? it seems to me that it would not help performance because it would heat up the air, and i thought a cooler, more dense air fuel mixture was better. any ides on wheather or not this is needed? i cant see any reason, except maybe on cold startup, i was planning on just plugging the coolant passage through the tbi base area off and routing the coolant like a carb 454 would have it. any info would be great, thanks in advance!
1987 GMC V3500 Sierra Classic
cmax87v3500 is offline   Reply With Quote
Old 03-04-2013, 07:52 PM   #2
Ziegelsteinfaust
Re: tbi intake question
For cold weather operation to keep the intake from icing up as I understand.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-05-2013, 01:14 AM   #3
rfmaster
rfmaster's Avatar
For 87 to 90 BBC TBI GM used a stock pile of cast iron (CI) Q-jet intakes with the well known plumber delight adapter plate. For 91 to 95 GM switched to aluminum intake. Aluminum heats up faster and it was a dedicated intake for Gen 5 BBC. Rumor has it that GM had a stockpile of Q-jet intakes and when they could not emission certify BBC with a carb for 87+ models they went with a bigger TBI on top of Q-jet intake.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 03-05-2013, 03:00 AM   #4
cmax87v3500
maybe i have you confused, i understand the cold weather idea behind the coolant running below the tbi (thanks Ziegelsteinfaust) but what i'm wondering is, cold weather aside, would it be possible to plug this coolant passage and just plumb the coolant like like it is on a carb intake?
Old 03-05-2013, 08:37 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I plugged all that junk on my 88 model 454. My heater hoses are now run just like traditional engines always did. No problems that I can tell.
Tx Firefighter is offline   Reply With Quote
Old 03-05-2013, 10:33 AM   #6
wyattglock
wyattglock's Avatar
I bypassed the baseplate on my tbi 454. No problems at all when it is cold out. I also opened up the air cleaner so it is now a 5" tall open element filter, still no freeze up problems and it has been that way for 2 years now.
wyattglock is offline   Reply With Quote
Old 03-05-2013, 03:41 PM   #7
cmax87v3500
thanks guys! thats the answer i was looking for, thats probably what im gunna do now too! thanks again!
3500, 454, gmc, k30, tbi
