#7101 |
Re: What did you do to your truck today?
Added a little bit of rust perventive paint on some bad spots until I can get the chance to start tearing it down.
Current project (My Maria) 62 Chevrolet LWB stepside ![]() 235 inline 6 cylinder http://67-72chevytrucks.com/vboard/s...d.php?t=569873 Dano |
#7102 |
This last weekend I finally got my cherry picker and engine stand, so I pulled out the donor motor from where it was sitting in the back of the bed and mounted it on the engine stand. I Degreased more of the donor engine, now that it is on the stand.
This upcoming weekend I will start pulling off the hood and front clip. Then its time to start removing the heads, intake and carb, and everything else off the blown engine and transfer them to the donor engine. After that, time to paint the engine. The engine paint that I bought ended up too greenish, so I am going to have to bite the bullet and buy some more engine paint that is the shade of blue I am looking for. I found some that will work out a lot better. I just don't want to get the engine installed and regret the color choice of the engine block and see that it clashes with all my blue accents (spark plug wires, distributor cap, radiator hose, etc.). Also got in my mirrors, so I might get them installed this weekend. After I took the engine out from the bed, the back rose up about 3 to 4 inches. Looked good with it down, so now I'm on the hunt for some TJ springs at a reasonable price. It looks super raked now.
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
#7103 |
Be pulling the cluster after work. Truck went to turn over 75999 on the odometer and stuck last night. I have a spare speedometer, but hoping the original just needs lubed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#7104 |
Just working on my motor.
#7105 |
#7106 |
I been stripping and stripping is hard work with or without the stupid pole.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#7107 |
![]() Join Date: Jan 2012
started putting some of the metal back on.... Just a trial fit.. Took it all back off so that I could finish the welds and smooth everything out a little better.. Dash will go back on this week and hopefully I can have the whole driver's side done this weel.. (fingers x'd..)I'm pretty dang happy with how this all came out..
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
#7108 |
![]() Join Date: Dec 2010
got some paint on it finally
#7109 |
#7110 |
few more pics, can't believe it's almost done
#7111 |
"Where were you in '62?"
![]() Join Date: Jul 2004
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#7112 |
weld up my new breathers and fill cap in my new valve covers.
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
#7113 |
here it is.
#7114 |
Lookin good !!!!!!
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#7115 |
I took the cab off the frame. All this was done by 2 people and no machines (except I used an SUV to pull the frame out of the way once the cab was off).
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#7116 |
shot some base and clear
#7117 |
Senior Enthusiast
Rewired the dash cam to draw power from the old electric clock circuit coming from the hot side of the battery disconnect. Now I can electrically shut down the entire truck and with the flip of a switch still leave the camera running, for example when left unattended in a parking lot.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#7118 |
63mouse,
What color and brand of paint did you use? It'll look really good after a cut and buff. Nice job! Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#7119 |
Pulled the hood and front clip off. Had my two 11 year old non-mechanically inclined boys helping me. Used the cherry picker for all of it. I was scared that one of them was going to let go if something and some of the body or paint would get damaged. They did fine, it was me that I should have watched out for... I ended up tweaking the grill surround (the part of the body above the grill) because I had the straps around it and the good release. The front clip wasn't coming off the frame. Stupid me! I hope I can bend it back some from the inside.
#7120 |
![]() Join Date: Mar 2005
Worked on my inner fenders for the last two days. It's a ton of work to do something custom and then try to make it all look factory
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#7121 |
![]() Join Date: Mar 2012
Installed a rear shock relocation kit with new lowering shocks, adjustable trac bar with relocation kit. Also wire wheeled my trailing arms and painted with eastwood extreme chassis paint and then installed new poly bushings. Need to finish the trac bar tomorrow and put the rear sawy bar on. Also installed my E brake setup from another board member and and works great.
![]() ![]() ![]() ![]() Posted via Mobile Device
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#7122 |
Dantimdad, thanks, ppg grabber blue
#7123 |
#7124 |
I picked up my new to me rear end in my trailer. Then when we (wife and I) got home we had to unload it & put it up on saw horses!
My wife said (after we got it out and on the horses) & I quote "This is not $ucking woman's work". It was really heavy and it was all she could do to get it out of the trailer and just hold it! She is a great woman for always helping me even when it hurts her! It was really to heavy for her to be lifting but she is a trooper and did it anyway! Posted via Mobile Device
People who make excuses didn't want to do it in the first place! ![]() http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
#7125 |
When you are doing the rear end double check your ride hieght against drive shaft clearance. I ran a 3 inch aluminum one piece shaft with the new 9 inch moser I installed . I had to grind some on the hoop in the frame. No big deal more than enough room though.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
