Leveling?
I have '70 c20 custom camper and want it to be level. The back sits higher as is so that when the camper is on it it sits level. How do i level it?
Posted via Mobile Device Posted via Mobile Device |
Re: Leveling?
go camping
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Leveling?
I think what cdowns is implying is that you're gonna need to supply more information.
If your truck is coil spring rear end, throw a pair of lowering blocks in there. If your truck has leaf springs, use drop shackles. There are other ways to skin that cat, but those are the quickest and easiest and will retain the full load carrying capacity of your 3/4 ton. Posted via Mobile Device |
Re: Leveling?
You could always put heavier springs up front to lift/level it.
http://67-72chevytrucks.com/vboard/s...d.php?t=556784
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Leveling?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Re: Leveling?
Thanks guys, thi wont be used for a camper shell though haha. Sorry for the lack of info. I like the bigger springs up front idea!
Re: Leveling?
I wish message boards had a Facebook style "Like" button!
Re: Leveling?
if you have the leafs you can take the bottom overload leaf out and it will allow the springs to relax a bit....giv you about 2 inches.
Re: Leveling?
it has leafs, are you saying if i take the overload spring out that it will lower? If anything then i think i want to raise the front, can i just put in bigger coil springs to do that?
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Leveling?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: Leveling?
