Old 03-06-2013, 10:43 PM   #476
Mattman2010
Mattman2010's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Well tonight I was going to start on welding all of the nuts for the bolts that hold on all of my rear suspension brackets but started looking at some things that i should probably get done before I start doing the boxing.
First off here is a picture of the steel that I will be using
The first problem I noticed was one of the cross members in the truck. The way it is factory made is really going to make it hard to go about boxing in that part of the frame. So I am going to cut it out and replace it with some 2x1/4.
I then also have to push my front rear spring hangers in toward the frame some. When I first mounted them they I did not notice that they where not flat against the frame and so I need to fix that and probably going to add 2 more bolts into the bracket to the frame.
The last thing I need to do is add some support for the bottom of the shackle flip bracket to the bottom of the frame.
One step forward three steps back it seems. Just gotta keep plugging along!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 03-08-2013, 01:27 AM   #477
Mattman2010
Well today I got the cross member cut out and got a new one tacked in place. I seemed to have forgoten to take pictures of it. I will tomorrow. I also added 2 more bolts to my front rear spring hangers and got them all pulled up tight to the frame so they are now correctly mounted. Should hopefully have all the templates I need made tomorrow so I can start cutting some steel!
Build Thread
Build Thread
Thread
Old 03-08-2013, 05:18 PM   #478
Mattman2010
Here is a picture of the new cross member tacked into place.
I was also able to make the templates for the steel for the rear part of the frame.
Build Thread
Build Thread
Thread
Old 03-11-2013, 11:03 AM   #479
Mattman2010
Well I started cutting out the steel for the rear. I hate using card board as templates as it flexes to much so when you transfer it to steel its usually to big. But it is probably better to have to grind it to fit so that it is a tighter fit.
Build Thread
Build Thread
Thread
Old 03-11-2013, 11:39 AM   #480
meatwagon83
meatwagon83's Avatar
hey you can come to my house and put a gooseneck hitch in my truck!!
meatwagon83 is offline   Reply With Quote
Old 03-11-2013, 10:26 PM   #481
ryanroo
ryanroo's Avatar
Looking good Matt!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-11-2013, 11:06 PM   #482
Mattman2010
Probably would be easier to bring your truck to my shop!
Originally Posted by ryanroo View Post
Looking good Matt!
Thanks man! Between you and Dieselwrencher I want to bag the rear of my truck too But i gotta get this hoe running.
Build Thread
Build Thread
Thread
Old 03-12-2013, 05:51 PM   #483
Mattman2010
Got the two other pieces cut that I need to cut for the driver side of the frame.
Got one on the passenger side cut and fitted into the frame, have one more cut out for the passenger side still needs fitted and the last one still needs cut out and fitted. Going to head back to the shop here soon.
Build Thread
Build Thread
Thread
Old 03-12-2013, 09:50 PM   #484
Mattman2010
And here are the last pieces cut and fitted.
Build Thread
Build Thread
Thread
Old 03-12-2013, 10:42 PM   #485
ryanroo
ryanroo's Avatar
Better get to burning wire, son.
also, i hope you trim that rec. tube. itll get all in the way when you bag the rear hangin down like that
72 K20 12v build
Old 03-12-2013, 10:56 PM   #486
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Ive tried to tell him but he doesn't listen... lol jk matt
BTW Ryan quit putting ideas in peoples heads! haha
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-12-2013, 11:03 PM   #487
ryanroo
ryanroo's Avatar
72 K20 12v build
Old 03-12-2013, 11:07 PM   #488
Mattman2010
Im going to need more wire and yes I will probably be cutting down the receiver tube. Wasnt really thinking about it seeing as there is 10 inches between the bottom and the pumpkin, but there is not really a need for the extra.
I dont listen to people who dont mess with their projects
Build Thread
Build Thread
Thread
Old 03-12-2013, 11:17 PM   #489
ryanroo
ryanroo's Avatar
Originally Posted by mattman2010 View Post
i dont listen to people who dont mess with their projects
bazang!
72 K20 12v build
Old 03-12-2013, 11:25 PM   #490
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
LOL I was waiting for that!
Tony
Old 03-13-2013, 10:23 AM   #491
Mattman2010
I figured if I keep giving you enough **** you may actually do something with one of your projects other than change oil...
Build Thread
Build Thread
Thread
Old 03-13-2013, 03:49 PM   #492
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Looking good Matt! Next you need one more turbo, one more clutch disc, and no rear leaves. Haha
Ryan
1969 Chevy milk truck
Old 03-13-2013, 03:53 PM   #493
Mattman2010
I think i need an engine rebuilt first!
Build Thread
Build Thread
Thread
Old 03-13-2013, 09:53 PM   #494
Mattman2010
Well first up my shop is a mess!
I then drilled all of my bed bolts through the bottom of the frame as well.
And I finally got my plates all tacked into place.
Now to just sling 32 feet worth of weld bead at it!
Build Thread
Build Thread
Thread
Old 03-13-2013, 10:42 PM   #495
Dieselwrencher
You're not done yet?
So, did you tunnel all the way to Iowa from Kansas and get one of my air bags today, and that's why you're not done welding yet?
And weld those extra holes shut son!
Ryan
Old 03-13-2013, 10:59 PM   #496
Mattman2010
Hell no!
And yes I did, but you came in right after I grabbed the first one so I couldn't steal the rest.
HELL NO. Do you know how many holes are in these damn frames?
Build Thread
Build Thread
Thread
Old 03-25-2013, 05:01 PM   #497
Mattman2010
So today I bought one of these.
And did this to it.
And it makes a shape like this.
and that is all you get till the next update.
Build Thread
Build Thread
Thread
Old 03-25-2013, 06:27 PM   #498
Dieselwrencher
I like your little tools to hold the metal together!
Ryan
Old 03-25-2013, 08:41 PM   #499
ryanroo
ryanroo's Avatar
Looks sweet, those little clamps look handy. now.... why didnt you have that broke wherever you had it sheared? i suggest some inside and outside weld on that baby on the bottom of the tank. and clean the shaz out of the joint area. get all the black surface coat off the edges where you are gonna weld to make sure it is a good weld so you dont have leaks in the future
Ryan
72 K20 12v build
Old 03-25-2013, 09:14 PM   #500
Mattman2010
Yeah the clamps are apparently for making picture frames they seem to wrk tho! And I didn't have it broke because I'm young and dumb and didn't think about that. Apparently I like to make things harder on myself. I planned on welding the bottom inside and out. Know of a good coating to put inside one of these bad boys?
Build Thread
Build Thread
Thread
