![]() Join Date: Mar 2012
Fleetside tail light replacement help
I'm replacing the tail light panel on my 63 fleetside and asking what guys have done to tack weld the panel back. I can drill some holes in the lower portion of the bedside to tack weld but no way to get in the top portion. I'm sure I'll figure it out eventually but that's usually after I've tore something up.
Thanks for any help. ![]() Posted via Mobile Device
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
Re: Fleetside tail light replacement help
Panel bond
That's what I was thinking. Cut the old one off without damaging the bed, clean up real good and get a good panel bond. I'll need to make sure to keep the seam between bed side and tail light panel clean so it looks good. Think I'll head to the local body supply shop and see what they have. I've heard good things about panel adhesives. Just seems weird not welding it. Thanks for your help. I figured more guys had done this.
![]() Join Date: Aug 2004
I have a pair also just havent done it yet, so Ill be watchin you
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#5 | |
![]() Join Date: Jun 2009
I'll be watching as well, that's double the pressure now!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
my buddy is a bodyman 30+ yrs, and I've seen that the metal will tear before the panel bond lets go on pickup rear bedsides. It is pretty amazing stuff.
#8 | |
I could also weld the joint on the outside and smooth it like I've seen on some other trucks on here. Just getting ideas.
Like this ![]() Posted via Mobile Device
This is what I ended up doing. I removed the lower section that I could spot Weld to the side panel.
Before picture. ![]() After I cut the lower section out. ![]() After all welded back together. ![]() Expoxy primered and ready for body filler and primer.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
