Old 03-11-2013, 02:08 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
A couple of 72 install questions; gas pedal and horn contact
My dad's 72 has been back from the body shop for a while and I'm trying to get it back together. They pulled a lot apart that I wasn't aware that they were going to and of course didn't put it back or even document anything.
They actually lost the gas pedal assembly. I found another one but I am installing it with new firewall insulation and it is a bear. I assume that the whole gas pedal Assy goes on over the cardboard, but I am having he'll getting all of the pieces lined up. Any ideas?
The second issue is the horn contact on the tilt wheel. They pulled the wheel off to paint the column and broke the horn cancel cam. The old wheel was toast and they tossed it. I bought a new cancel cam and contact from LMC but there is no groove in the tube on the cancel cam like shown in the photo. I have never dis assembled a 67-72 set up before, but have done a lot of post 73 gm's. Normally you put the contact in and turn it half a turn or so. Do I need to send the LMC part back and buy local?
WIDESIDE72 is offline   Reply With Quote
Old 03-21-2013, 08:09 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: A couple of 72 install questions; gas pedal and horn contact
50 views and not even a guess
Old 03-21-2013, 08:58 AM   #3
vidman
vidman's Avatar
My pedal assembly was over my firewall padding when i removed it a few weeks ago. I can,t help you on the horn contact. I removed it in one unit.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 03-21-2013, 12:50 PM   #4
bronze 72 super
bronze 72 super's Avatar
Just went out to my shop and looked at some spare tilt horn contacts I have. All of the tilt ones I have are black in color, there is a small red barrel shaped insert that goes inside. A spring is at the bottom. The metal horn contact goes though the insert. The insert is grooved right in the middle, this holds it in place. The contact has a "foot" at the bottom that compresses the spring. I've looked at what LMC sells. Its' not complete set up. Try to post a thread looking for a complete set up. If Mel at Classic Chevy in Oregon reads this, he more than likely has one. He also has a thread as to what you need, you will need to research the thread. Hope this is helpfull. Mike.
bronze 72 super is offline   Reply With Quote
