Old 03-11-2013, 08:10 PM   #201
OrrieG
OrrieG's Avatar
Re: 1955 12 Valve NAPCO Clone
Somewhere there is a photo of a bed with one full length board hinged to access the gas filler. I think the guy used Blum cabinet hinges.
Old 03-11-2013, 11:29 PM   #202
Luther Grimace
Luther Grimace's Avatar
I'll have to try and find it.
Before
After
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 03-12-2013, 12:07 PM   #203
cAlvis165
cAlvis165's Avatar
Gauges look great! Just wanted to say I've been following this build and love what you're doing with the truck. Here's the post that shows the flip up slat in the bed. Hope it helps.
http://67-72chevytrucks.com/vboard/s...&postcount=300
Chad
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 03-12-2013, 12:18 PM   #204
Luther Grimace
Thanks man! I read through your build thread over on Corn Binder. I love your truck. A buddy of mine has an old Scout 2 with the 4 cylinder. What kind of wheels and tires are those? Also I like your paint scheme and you mentioned that International Stacey David is building. That truck is pretty sweet. It looks awesome just like it sat when he drug it out of the junkyard. But I am kinda partial to junkyard rescues.
Old 03-12-2013, 12:37 PM   #205
cAlvis165
cAlvis165's Avatar
The wheels are 16.5" by 10.5". The have some old 38.5" Ground Hawgs on them. The tires have been siped and are shake your teeth out at about 35 mph. Once you get the truck up to speed the ride isn't too bad...just real loud! Looking for some 37" HUMVEE take offs to replace them.
I've enjoyed watching the Heavy Metal build on Gearz. Would have been great if he had kept the engine a IH and used a DT466. But that Duramax is going to be able to toast those tires.
Back to you build, now. Keep up the great work!!
Old 03-12-2013, 05:09 PM   #206
Luther Grimace
I am looking at getting a new complete wiring harness from Classic Truck Parts of America. It would be the alternator setup for the original harness. Anybody have any experience with this kit? I think I will prolly use one of the junction block fuse kits you can get from a chain auto parts store to add my electric fan relay and any other things I might add later.
Old 03-15-2013, 10:30 PM   #207
Luther Grimace
Got my pump put back together. Good news and bad I reassembled the pump with components from a used one and got it installed and running. Bad news is that it still has a miss I'm at a loss. I'm thinking about getting new 5 x 12s because that's all I have left that I can think of.
Old 03-16-2013, 09:51 PM   #208
6BT 56
6BT 56's Avatar
Hi luther . I used the american auto wire kit in my truck. It was the best kit! I cant say enuf good stuff abt it. It was clearly labeled . I wired the whole truck headlight to tail and EVERYTHING inbetween in abt 14 hrs. The dist hook up for the gm hei is just rite for the cummins as well.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-16-2013, 10:49 PM   #209
Dan in Pasadena
Dan in Pasadena's Avatar
Hmmmm, Orrie you've got me thinking. (And that's always dangerous!)
I've seen the trailer queen show trucks that have the remote-controlled, servo operated bed board that lifts and if I'm honest I kinda roll my eyes at the pretentious-ness of that (strictly my biased opinion). But now with your comment, I'm thinking why not do it without all the remote controlled stupidness and just have a hinged board that doesn't look like it's hinged?
I'm thinking the bed strip would be attached to the hinged board and act as the "stop" for the board as well as be where the magnetic (or something) latch would be mounted. I've gotta think about this. If anyone has any ideas about this, I'd love to hear them.
Dan in Pasadena is offline   Reply With Quote
Old 03-16-2013, 11:48 PM   #210
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I'd try to do the small board behind the wheel well and just make that one flip up like delmo did with that full board but make the strip flip up like you said. That's how I was picturing it and it won't stop you from filling up the truck if something is in the bed.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-17-2013, 08:20 PM   #211
Luther Grimace
Thanks 6bt. Hope y'all have had a safe trip! This was the harness I was planning on running since I have no future for power windows, cruise and what not.
http://www.classicparts.com/1955-59-.../#.UUZdDDeyLIY
Also I got some of those hinges from Lowe's yesterday for $3 a piece. I think I am gonna use the short board theory like y'all said. I won't have the metal strips separating them since I'm going for a more old work truck look.
I drove the truck on Saturday and hope to post a video up soon. If I could ever figure out this miss I will be burning Bias ply rubber!
Old 03-18-2013, 02:22 PM   #212
6BT 56
6BT 56's Avatar
That harness looks a lot like the 1st one i tried. I hope its better. I looked at the 1st one for 20 min and thought no way. Put that pos in the box and sent back. I can honestly say I am good at electrical stuff, that harness was not labeled at all . the diagram was a joke . Cheep yellow and blue ring terminals all over. The AAW was twice the $$$ but no way I could have done a whole truck with the other harness in 14 hrs .
I wish I knew who built my 1st harness so I could say for sure . It does look very similiar tho.
I put a post up on my page abt the fuel pin .
How bad is your miss?
Old 03-18-2013, 03:53 PM   #213
Luther Grimace
It is a pretty significant miss. It is enough to make the engine shake hard. I changed the fuel filter, left the fuel cap off (and I just realized that it is still off and it is raining outside ), and I also pulled the fuel return off to see what was coming out of it and I am getting alot of flow through it. I feel like it is more than it should be.
You can see in these pictures that I realized my old injection pump was very gaulded up. I used all the parts from my new parts pump except for the case. My timing piston was gaulded in its bore so I took some 1000 grit wet paper and smoothed the bore out.
Old Used
New Used
Here are links to the videos. The truck is going slow because I don't have the gas pedal hooked up yet so it was just idling.
http://s943.photobucket.com/user/Lut...30ed5.mp4.html
http://s943.photobucket.com/user/Lut...30b13.mp4.html
Daddy and I also started working on the panel alittle also.
Old 03-18-2013, 03:59 PM   #214
Luther Grimace
[QUOTE=6BT 56;5955028]That harness looks a lot like the 1st one i tried. I hope its better. I looked at the 1st one for 20 min and thought no way. Put that pos in the box and sent back. I can honestly say I am good at electrical stuff, that harness was not labeled at all . the diagram was a joke . Cheep yellow and blue ring terminals all over. The AAW was twice the $$$ but no way I could have done a whole truck with the other harness in 14 hrs .
I wish I knew who built my 1st harness so I could say for sure . It does look very similiar tho.QUOTE]
I would reuse mine if I could get some more hookups to my gauge lights. They broke off and I can't figure out how to reattach them.
Old 03-18-2013, 10:07 PM   #215
6BT 56
6BT 56's Avatar
Its funny you say that abt the dash lights. My american autowire harness came with new connectors and sockets for the bulbs. It looked like too much work tho so i Reused the orriginal ones and shrink butted them to the new harness. Cheater . Lol. Call AAW . They make the connectors. maby you can just buy a pak of em.
Old 03-19-2013, 02:49 PM   #216
Luther Grimace
Good news. I purchased some instrument cluster light bulb sockets from Rock Auto. I'm gonna use these and get my gauge cluster back in.
Old 03-19-2013, 05:39 PM   #217
OrrieG
OrrieG's Avatar
Can you post the rockauto pn for the sockets? I searched and all I could find were the lamps. I am one short....
Old 03-19-2013, 06:09 PM   #218
Luther Grimace
Here is the part #
http://www.rockauto.com/catalog/more...398&cc=1326259
When you search for it on Rock Auto search this like this
Chevrolet>1956>Truck>3.8L 235cid L6>Electrical Lamp and Socket> Instrument Cluster Lamp Socket
Hope this helps. I might end up with them and they don't work. If you wanna wait i'll let you know how they fit and work.
Old 03-19-2013, 08:24 PM   #219
OrrieG
OrrieG's Avatar
Thank you, during lunch I stopped by NAPA with a part number I found Sunday (they are closed) and they had one on the shelf. I posted on the main board. It was $7 but I figured I'd pay that for shipping from out of town.
Old 03-19-2013, 10:11 PM   #220
Luther Grimace
I had to pay 8 dollars for shipping so don't feel bad!
Old 03-21-2013, 11:55 PM   #221
6BT 56
6BT 56's Avatar
Any luck with the miss?
Old 03-22-2013, 10:05 PM   #222
Luther Grimace
No luck. I think I will have to let a professional do it. All the instrument cluster gauge lights I bought are wrong also.
Old 03-23-2013, 11:43 AM   #223
6BT 56
6BT 56's Avatar
For whats its worth a diesel guy once told me on the older mechanical engines . You could remove the exh manifold , run the eng and look at the exh ports to see what cylinder is kicking and making a fuss. then swich injectors from that cylinder and see if the miss moves to another cyl. If it moves , injector is ng. If not . Do compression and leak down on that cylinder. If you give it a shot of ether does the miss go away ? Is it even at idle for that matter? Why did that eng come out in the first place ?
Old 03-23-2013, 11:56 AM   #224
Luther Grimace
My pump is the problem. With an injector cracked it won't even spray out it just spills out slow.
Old 03-23-2013, 04:54 PM   #225
6BT 56
6BT 56's Avatar
Yep that would do it.
