Old 03-11-2013, 09:58 PM   #276
Chris.
Re: 1949 Chevy 3600 into a daily driver
Looks awesome man! this is really giving me motivation to keep on moving forward with mine.
Chris. is offline   Reply With Quote
Old 03-11-2013, 10:20 PM   #277
Dan in Pasadena
Dan in Pasadena's Avatar
Looks good. Do they rub up front?
Dan in Pasadena is offline   Reply With Quote
Old 03-11-2013, 10:38 PM   #278
Coach529
Coach529's Avatar
nope......have plenty of clearance at full lock.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-11-2013, 11:03 PM   #279
Dan in Pasadena
Most kewl! You did something right in your planning. Kudos.
Found a source for the rear spacers yet?
Old 03-12-2013, 01:33 AM   #280
Dan in Pasadena
By the way, even though I've got a Task Force remind me what your lowering setup is? Did you have all new leaf spring packs with a 3" (?) Sid's dropped axle? Or are your spring packs "lowering" springs?
Partly the reason I'm asking is today I (embarrisingly admit) I noticed I've got 5 leaves on my driver's side but 6 leaves on my passenger's side.....and it sits level!! So something's gotta change.
Old 03-12-2013, 09:33 AM   #281
Coach529
Coach529's Avatar
http://www.roadkillenterprises.com/5...-bolt-pattern/
1949 Chevy 3600
Old 03-12-2013, 09:33 AM   #282
Coach529
Coach529's Avatar
Front is stock springs with 2 leafs removed and a 4" Sid's axle.
1949 Chevy 3600
Old 03-12-2013, 09:56 AM   #283
xpickup
xpickup's Avatar
Coach529, looking good. It is going to be a great looking daily driver.
Shannon
xpickup is offline   Reply With Quote
Old 03-12-2013, 12:19 PM   #284
Coach529
Coach529's Avatar
Shannon
That is the hope.......thanks!!
1949 Chevy 3600
Old 03-12-2013, 01:59 PM   #285
Dan in Pasadena
Coach, hope you don't mind a couple more questions?
On the forward end of my front leaves, the shackles have some rubber that; for lack of a better description, is "squishing" out. I assume this rubber was (???) in between the pin and the shackle to isolate vibration? Do you know what these are called? Ate thes parts that require the leaf pack to be removed in total so they can be pressed in? Or could I simply support the leaf pack end with my floor jack, remove the pin with a hammer & punch and replace this...whatever its called?
Sorry to kinda hijack. I hope you don't mind.
Old 03-12-2013, 01:59 PM   #286
Dan in Pasadena
Are these parts that require the leaf pack to be totally removed so they can be pressed in? Or could I simply support the leaf pack end with my floor jack, remove the pin with a hammer & punch and replace this...whatever its called?
Old 03-13-2013, 07:34 PM   #287
ChevyBrad
ChevyBrad's Avatar
Coach, your build is coming along great! Thank you for all the step by step pictures and descriptions. I am currently starting a build with a 3800 along the same lines, only I am shortening it to a short bed. I hope mine turns out this good.
ChevyBrad is offline   Reply With Quote
Old 03-13-2013, 07:43 PM   #288
focusedontheprize
focusedontheprize's Avatar
Mike,
I was looking at the pictures of the truck on all 4. Are you happy with the rake or is that changing?
focusedontheprize is offline   Reply With Quote
Old 03-13-2013, 07:53 PM   #289
Coach529
Coach529's Avatar
Originally Posted by focusedontheprize View Post
Mike,
It is going to change. Hoping to drop the back end a couple more inches.
1949 Chevy 3600
Old 03-18-2013, 04:47 PM   #290
Coach529
Coach529's Avatar
We had a pretty good shot of snow yesterday and last night.....combined with 40mph winds today.
School cancelled, but my wife had to work. Snow day for kids.....shop day for dad!! :-)
In between some other tasks and moving snow I got some stuff done today!!
Got my pinion set and burnt in the spring seats.
After that I bolted the Blazer sway bar on the rear end and shortened up the vertical mounts to use it on Henry. Fits perfect!!
I then spent about an hour boxing the spring mounts I made.
The UPS man.....and Mail Lady have been making alot of delivery's to the household lately!!
My wheel spacers showed up.
And I got a special package from Wood1........tail lights and a center steering wheel cap!!
Up next:
* Box frame
* Fab cross member for upper shock mount
* Fab lower shock mounts and install shocks
* Fab upper front shock mounts
1949 Chevy 3600
Old 03-18-2013, 06:33 PM   #291
Chris.
Between the snow and the new stuff it must feel like Christmas! Haha. It's looking good man!
Old 03-18-2013, 07:24 PM   #292
Coach529
Coach529's Avatar
Yes sir......always nice when packages of shiny stuff arrive!!
1949 Chevy 3600
Old 03-18-2013, 07:25 PM   #293
Dan in Pasadena
Yeah, except when it's Christmas someone ELSE pays for the stuff you get!
Old 03-18-2013, 07:30 PM   #294
Coach529
Coach529's Avatar
True....
1949 Chevy 3600
Old 03-18-2013, 07:49 PM   #295
NEWFISHER
NEWFISHER's Avatar
What year blazer did you rob the sway bar from? Looking good!
Edit: you have a 3600 and I have a 3100 with a 10" narrower frame in the rear, mabey the s-10 blazer bar will be too narrrow.....anyone with a 3100 hang one or just look for the camaro rear?
NEWFISHER is offline   Reply With Quote
Old 03-18-2013, 07:54 PM   #296
Coach529
Coach529's Avatar
It was a 1997 or 1998 Blazer. Perfect width for the 3600 frame. It would require some sort of cross member and mounts to work on a 3100 frame I am afraid.
1949 Chevy 3600
Old 03-18-2013, 09:51 PM   #297
Dan in Pasadena
Coach, Whats going on with your bed?
Old 03-18-2013, 09:56 PM   #298
Coach529
Coach529's Avatar
Nothing......it is sitting out on a concrete slab in the snow.
After I build all my shock mounts, and run brake lines and electrical we will bolt it back on.
1949 Chevy 3600
Old 03-18-2013, 10:05 PM   #299
Chris.
Not at my house, haha
Old 03-18-2013, 10:12 PM   #300
Dan in Pasadena
Ssshhj... You're living in the WRONG house! Lol.
