03-13-2013, 07:10 AM | #1 |
Do I need a Fuel Return Line?
Im installing a Boyd welding rear mount gas tank on a stock 72 small block setup. Do I need to run a fuel return?
Thanks Posted via Mobile Device |
03-13-2013, 08:22 AM | #2 |
Re: Do I need a Fuel Return Line?
Depends on your fuel delivery set up. If you have a mechanical pump and your carb setup takes the full pressure you shouldn't need one. If you have a high pressure pump and any fuel is bypassed you'll need a return line. I believe some hp mechanical fuel pumps came with a bypass port. If this motor is the same as before the tank swap and you did not run one then...no, not needed.
03-13-2013, 06:05 PM | #3 |
its the stock pump and stock carb.......
03-14-2013, 06:26 AM | #4 |
ttt
11-14-2015, 08:26 AM | #5 |
Im sure you got it all worked out already, but no you dont with the stock set up.
