Old 03-13-2013, 09:04 AM   #1
cochino12
It followed me home?
cochino12's Avatar
another 3/4 to 1/2 conversion ?
So my 3/4 ton has a 14b ff and I am trying to swap to either a 10 or 12 bolt rear. I know the spring perches are located in different widths and I'd rather not change the perch locations on the 1/2 ton axle.
the frame's are the same width right? so I could swap to the 12 bolt by ordering some new front and rear hangers ?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-13-2013, 09:13 AM   #2
Jonboy
Slots go on anything!
Re: another 3/4 to 1/2 conversion ?
It seems like when I swapped my '75 Blazer to 1 ton diffs, they bolted to the stock springs. That was a long time ago, but I am 100% positeve the only thing I had to do was get bigger u-bolts made.
Jonboy is offline   Reply With Quote
Old 03-13-2013, 10:12 AM   #3
meatwagon83
meatwagon83's Avatar
Why didnt you just buy a 1/2 ton?
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 03-13-2013, 10:14 AM   #4
cochino12
cochino12's Avatar
because GM didnt make a 2wd 1/2 ton crew cab short for me. thanks for the help
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-13-2013, 10:39 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
One tons are narrower. 3/4 are the same.
Brakes hoses where different up front.
Old 03-13-2013, 10:48 AM   #6
83GMCK2500
x2, 10 bolt or 12 bolt will bolt right into your truck.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-13-2013, 11:51 AM   #7
cochino12
cochino12's Avatar
I thought they were the same too, the perches on this truck are closer toghether than the 10 bolt I have in my 83 c10
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-13-2013, 02:02 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
I cheated when I did the brother n laws crew.
Got 1/2 spindles reamed for 3/4 ball joints.
Old 03-13-2013, 02:12 PM   #9
83GMCK2500
Post/share your VIN, I'm curious if your 3/4T is a rebadged 1-Ton.
EDIT: 6th Digit: 2 = 3/4T, 3 = 1T.
Devin
New Daily, the '96
Old 03-13-2013, 06:56 PM   #10
cochino12
cochino12's Avatar
6th digit is a 2, 1gcgc2...
pin to pin measures 40" w/2.5" leaf springs.
So, anyone know if I can use 1/2ton hangers?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-13-2013, 07:13 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
Shocks inside of frame?
Anyways the one i did just bought new spring pads. Seemed easier than changing hangers
Old 03-13-2013, 07:22 PM   #12
mattcrp1
mattcrp1's Avatar
are the 3/4 ton and 1/2 rear axles the same? as in drums and width?
mattcrp1 is offline   Reply With Quote
Old 03-13-2013, 07:24 PM   #13
cochino12
cochino12's Avatar
yep, they are inside the frame.
I think it would be much easier to just buy new pads, I may be add a kp 4link/cantilever in a few months and didnt want to have to move the pads again.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-13-2013, 07:29 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
One ton hangers. Maybe it depends on the gvwr.
1/2 t shocks are outside the rail as you know.
Old 03-13-2013, 08:36 PM   #15
mkdesign
mkdesign's Avatar
My conversion was fairly straight forward. I used the complete rear components ( rearend, springs and 1-piece driveshaft) from a donor 1/2 ton and it was a straight bolt in to the original spring hangers. On the front I used a pair of Early Classic Enterprise 3/4 ton 1/2 ton 2 1/2 drop spindles. You retain the stock 3/4 a-arms, ball joints and tie rods,and even the calipers. The only parts from the 1/2 ton I used for the front were the rotors and new pads. Saves a ton of work and I would suggest this option any time. I would have thought I may have had brake issue because of the difference in rear brakes but the brakes are as good if not better than before the conversion. You can check out my build thread titled "Charity Case" and it may have more info. Hope this helps. Oh and to answer the question of why not just buy a 1/2 ton in the first place? As for me, the chances of finding a 1/2 ton with the color, options, and condition that came with my 3/4 ton were slim to none so I grabbed it.
mkdesign is offline   Reply With Quote
Old 03-13-2013, 08:52 PM   #16
meatwagon83
your welcome, now point out where in the post you say anything about it being a crew short bed, how was i supposed to know?
Old 03-15-2013, 10:39 PM   #17
kevinr1970
That kind of responce comes up everytime someone asks about changing from or to something the truck didn't come as.
Like going to 1/2 ton from 3/4 ton (like I did) or going from Dually to SRW (like I am planning on doing).
Some people just get tired of that responce when they are trying to figure something out by asking questions here?
It's my truck and i will do what I want with it!!!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
