Old 03-13-2013, 01:47 PM   #1
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Error when using search
Anyone else getting this error when you try and use the search function?
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 35 bytes) in /home/admin69/public_html/vboard/search.php on line 1155
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
Old 03-13-2013, 01:51 PM   #2
~Whitey~
~Whitey~'s Avatar
Re: Error when using search
works fine for me
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 03-13-2013, 01:55 PM   #3
~Whitey~
~Whitey~'s Avatar
What's the search phrase your using?
Jimmy
.69SWB Build.
Old 03-13-2013, 02:15 PM   #4
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
locking rear axle
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-13-2013, 02:30 PM   #5
dmw319
i get that from time to time too.
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 03-13-2013, 02:43 PM   #6
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
never had a problem before last night, now still problem this morning and afternoon. Hopefully it will work tomorrow..
Anyone want to do that seach and then post the link to it?????
locking rear end
Trying to get a pic of what the locking rear end from 1970 would look like. Spid label says locking rear end for a option, but it just doesn't look right.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-13-2013, 02:46 PM   #7
dmw319
Well what do you know, I got the same thing again too!
Old 03-13-2013, 03:04 PM   #8
camrycurt
camrycurt's Avatar
I get that alot too. When it happens I usually just log out for a while and it usually works later when I check back in.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 03-13-2013, 03:27 PM   #9
71K20chevy
71K20chevy's Avatar
I, too, occasionally get that. I usually just wait and it resolves itself.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-13-2013, 03:42 PM   #10
SS Tim
SS Tim's Avatar
Originally Posted by bcj67chevy View Post
...locking rear end...Trying to get a pic of what the locking rear end from 1970 would look like. Spid label says locking rear end for a option, but it just doesn't look right.
The stock rear for a 70 Blazer is a Chevrolet 3500 AKA 12 bolt. There is no way to identify a posi rear end by a glance as it is the same housing. It may have a tag on a diff. cover bolt. The rear end should have a build number that includes a ratio/application code. If you can find this we can try to look it up. Often it is just easier to pull the cover and inspect the diff.. Most never get the fluid changed often enough.
SS Tim is offline   Reply With Quote
Old 03-13-2013, 03:50 PM   #11
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
i have the cover off right now.. Anyone got any pics of a 70's locker?
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-13-2013, 04:02 PM   #12
~Whitey~
~Whitey~'s Avatar
here's a pic of my 373 posi from a 71
Jimmy
.69SWB Build.
Old 03-13-2013, 05:09 PM   #13
SS Tim
SS Tim's Avatar
That is a typical Eaton style posi that would have been factory installed. The preload springs are the giveaway. How about a picture of your diff. and the axle code if you can find it?
Old 03-13-2013, 07:07 PM   #14
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
No spings on mine, i figured that...
The spid label says positraction, so someone must have changed out the whole axle or just the internals.
Anyone know how many teeth would be on a 3.73 ring gear?? spid label doesn't say 3.73 .. hopefully they at least went to a good ratio. The front diff internals look like new, the inside spool inside that holds the ring gear is painted black..
I will post pics shortly or mine..
Thanks guys
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-13-2013, 07:43 PM   #15
SS Tim
SS Tim's Avatar
Just count the teeth and divide. The ring gear might have the tooth counts stamped into it.
Old 03-13-2013, 07:58 PM   #16
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
43:13 so 3.08 i guess
Im suprised tgey use this on a 4x4 blazer.
This might be slow off the line w 33x12 tires.
Hopefully it will help gas mileage.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-13-2013, 07:59 PM   #17
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
43:14 so 3.08 i guess
Im tgey use this on a 4x4 blazer.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-13-2013, 08:20 PM   #18
SS Tim
SS Tim's Avatar
3.07 gears were standard with a 350 as were E78/15B tires.
Old 03-13-2013, 08:31 PM   #19
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Would 3.07 gears be better than 3.73 gears for gas mileage ?
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-13-2013, 08:52 PM   #20
SS Tim
SS Tim's Avatar
33s should just about kill any chance of mileage you have with 3.07 gears as they make the effective ratio about 2.56. Figure that the stock tires were 26.6" in diameter and your 33s are about 32". So basically you have a tire 5.4" taller and nearly twice as wide plus it is heavier. The only time those gears are helping you are downhill or parked on a grade. You can use a tire gear calculator if you want but the difference is about the same as changing to 3.73 gears. This would give you about the same highway RPM with the 33s as the factory setup was with the E78/15 tires. Now this does not even take into account the extra mass of the wheels and tires. Rule of thumb used to be go to the next lower step after correcting for RPM. So you might actually be happier with 4.11s but 3.73s should give about the best possible mileage IF YOU DO YOUR PART!
Old 03-13-2013, 09:09 PM   #21
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Thanks for the info.. guess ill stick with thw 3.07 for now.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
